How To Remove Paint Stripper From Concrete Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-08-2013, 11:58 AM   #1
How to remove paint stripper from concrete floor
In a 13 x 15 room in the basement, we stripped off the vinyl flooring using a rented vinyl floor stripping machine, mopped with simple green and let it dry overnight.
Then, we used the BEHR Concrete Paint Stripper to remove the paint stains on the floor. We applied it with a brush on the areas that had paint droppings and let it sit for 4 hours.
We're now trying to remove the stripper but it's a gooey mess. A mop and water just spread it around, as does a stiff brush. I've used a scraper to pile most of the goo into a pile and then used my shop vac to vacuum it up, but there's still a very slimy residue that's left.
In another room in the basement (no vinyl floor, just carpet), we used the same BEHR product and was able to mop it up. Maybe the vinyl floor left a glue residue?
How can I remove the stripper???
elyders is offline   Reply With Quote
Old 06-08-2013, 12:08 PM   #2
Rewards Points: 13,446
What's it say to do on the the can of stripper?
Old 06-08-2013, 12:16 PM   #3
The BEHR products says "Use a scraper, squeegee or pressure washer to remove all coating and residue."
I used a scraper, but that still left a layer of gooey slime. I'm afraid of using a pressure washer in the basement, where do I wash the gooey slime to?
Maybe a squeegee? That's the only thing I haven't tried.
Otherwise, I was thinking of a strong degreaser.
Old 06-08-2013, 10:08 PM   #4
Rewards Points: 4,578
xylene BUT turn off ALL sources of ignition as its flammable,,, never having used ANY behr products, that's all i know to do,,, there are strippers that are safer - ' franmar ' comes to mind ( soy ),,, its NOT cheap, tho
Old 06-09-2013, 06:38 PM   #5
xylene BUT turn off ALL sources of ignition as its flammable...
Thanks for the suggestion, but we decided it's not worth the hassle of using such harsh chemicals.
We're now going with carpet.
Old 06-09-2013, 06:55 PM   #6
elyders, what did the people at behr OR the apron store tell you BEFORE you posted it here ?
Old 06-10-2013, 06:52 PM   #7
I sent an email to BEHR last Thursday, but have not received a reply, yet.
Home Depot, where I bought the BEHR product, was of no help. The sales rep basically read the back of the can to try and figure out what to do.
Old 06-10-2013, 07:24 PM   #8
you expected different from an apron/vest wearer ? at least he could read don't know many pro's who used behr but, since the apron store started advertising, many h/o's think its great go figger !
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
remove old paint from concrete basement floor figureitout Flooring 3 12-30-2012 02:18 AM
Epoxy Paint on Previously Painted Concrete Floor goodkarma Painting 6 07-10-2008 01:04 PM
