Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-02-2012, 03:53 PM   #1
How to remove mold/mildew from brick
Moved into a house where on the north side there is some mold/mildew that grew on the siding as I guess also on the brick. I know how to wash the siding but how do I wash the brick? I just want it to not be green/mildew-ey, but I want to be safe.
MLMIB is offline   Reply With Quote
Old 03-02-2012, 07:31 PM   #2
Super Moderator
Hot soapy water with some bleach---bleach will kill the moss and any mildew---might take a couple of tries--
Use a scrub brush--
Don't be tempted to use a power washer---The mortar could get blasted loose---Mike---
Old 03-02-2012, 07:39 PM   #3
I use the outdoor Clorox in a pump sprayer, let it sit 1/2 hour then pressure wash it. Just do not get up close and use a fan spray nozzle not a fine point.
Keep it moving, do not stay in one spot.
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Ugly brick on front of house jetrep General Discussion 5 06-01-2011 07:58 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
