Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-30-2012, 11:12 PM   #1
How to prevent foundation from cracking?
Hello everyone,
I'm in a lot of trouble . I had a rusted bathtub drain pipe. While trying to remove it and and the rusted pipe elbow broke off. I need a way to cut through the foundation w/o causing cracking the foundation. Can someone please recommend a proper method for it? Thank you so much everyone for your time!
bcdinh is offline   Reply With Quote
Old 06-30-2012, 11:23 PM   #2
Once it's cut off on both sides of the wall the pipe can be split from the inside of the pipe and slid out in two pieces.
Old 06-30-2012, 11:29 PM   #3
awesome..that's a great idea joecaption!
Old 06-30-2012, 11:42 PM   #4
A real plumber would also know where the cleanouts need to be so if it plugs up it can be snaked.
Old 07-01-2012, 02:03 AM   #5
liscenced electrician
is that cast iron? Cast iron is a pain to cut. Use cutting discs on a grinder to cut as close to the wall as possible, Im not sure how to cut the piece in concrete. I looks like the concrete square around the pipe was patched in afterwards
jimmy21 is offline   Reply With Quote
Old 07-01-2012, 02:11 AM   #6
Yes. its cast iron. Im planning to use a dotco to cut it.
Increasing height of Steel Bulkhead Concrete Foundation ulrichfolkers Concrete, Stone & Masonry 5 06-18-2012 10:40 AM
How to stub off an old stone and mortar foundation beautah Concrete, Stone & Masonry 0 04-25-2012 10:43 AM
Foundation crack on old milk barn. How to fix?? esblair Concrete, Stone & Masonry 2 02-20-2012 01:34 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 09:31 PM
