Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-28-2012, 07:42 PM   #1
Homerepairguy's Avatar
How to pour a replacement piece of footing?
How should I pour a replacement piece of concrete footing at the corner of a concrete slab with shrinkage in mind?
Our home is 40 years old and built on a concrete slab. The ground slopes slightly from front to back. The shoddy contractor poured a concrete footing on top of the ground at the back of the house to help support the back end of the slab. The footing is 13" wide x 7" high and extends the length of the back of the concrete slab. The back end of the slab rests on the footing with about 4" of the footing sticking out.
A 20" piece of the footing at the left corner cracked off and was rocking back & forth so I removed it. The piece is about 13" wide x 7" high x 20" long.
I want to replace the piece using Quickrete. I can build a form to hold the concrete when i pour it but am wondering about the concrete shrinking as it dries and therefore not offering any support for the slab at the corner. It's not that critical since the slab is resting on the dirt and on the remainder of the footing but I want the replacement piece to help support the corner as much as possible.
Any suggestions on how to do the job?
Sky
Homerepairguy is offline   Reply With Quote
Old 02-29-2012, 08:10 AM   #2
Disabled wood vet
titanoman's Avatar
There must not be any rebar in the footing I guess.
I would drill into the existing footing and get some rebar pins in there to keep separation from the existing to the new to a minimum.
Concrete doesn't shrink enough to be a concern, either.
titanoman is offline   Reply With Quote
Old 02-29-2012, 01:51 PM   #3
Sounds like good advice and I'll follow it.
Thanks,
HRG
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 02:41 AM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 03:20 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 03:22 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 11:12 AM
