Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-27-2012, 12:58 PM   #1
How to pour a concrete sidewalk on a hill??
I tore down an old wooden deck in my back yard, and now I have 2 disconnected ends of a sidewalk with a slight hill (maybe 3'/15') between them. I'd like to connect the 2 with a new sidewalk in between, but I'm not sure how to do it correctly to prevent it from cracking, especially since it's on an incline. Any advice? Thanks.
dustymcuga is offline   Reply With Quote
Old 09-27-2012, 02:30 PM   #2
Don't add a lot of water to your concrete...and you can also use some 6" x 6" wire and it will be stronger.
JonM is offline   Reply With Quote
Old 09-27-2012, 05:14 PM   #3
Just pour it at a low slump,2-3 inches should work.
Canarywood1 is offline   Reply With Quote
Old 09-27-2012, 05:19 PM   #4
concretemasonry's Avatar
If you are going 15' on soil that may not be the best or right, make sure you have joints to control where the cracks will be and not show. If you do not have the right base, no sidewalk will span structurally over 15' without cracking sooner or later.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
mae-ling (09-27-2012)
Sidewalk Concrete Forms next to house jimsi Concrete, Stone & Masonry 2 05-25-2012 11:30 AM
5 inch gap between a sidewalk & concrete blocks Cindy8511 Landscaping & Lawn Care 1 04-11-2012 11:41 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
concrete forms for a sloping sidewalk? walkman Building & Construction 5 05-17-2009 07:54 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-25-2005 12:40 AM
