How To Make Cut Curves In Stacked Stone Tile - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-07-2015, 03:20 PM   #1
How to make cut curves in stacked stone tile
Hello all,
I wanted to add some stacked stone on one of my walls. The problem I'm running into is figuring how to cut curves into the stone so it can fit the top portion of the wall. The stones come in 6x24 inch slabs. The wall is about 7ft wide by 6ft tall. What tool would be best used to cut a curved line into the stone?
The wall
2 pieces of stones on top of each other
ahmadhasib is offline   Reply With Quote
Old 05-07-2015, 04:46 PM   #2
Rewards Points: 2,796
Try a diamond wet saw, adjusting the depth a little at a time.
making a series of kerfs, a small space apart, then use a stone masons chisel to slowly chip out each piece of leftover stone, to make a close enough arch.
Then cover it with a flexible molding as a finish.
ED
de-nagorg is online now   Reply With Quote
Old 05-07-2015, 05:20 PM   #3
Rewards Points: 1,232
To make it look correct, i.e. realistic, you need a different stone to edge it with, or even a brick if that fits the rest of the motif. Then you use "L" corners and wrap around the arch, then miter cut into that.
The truth is, I would not do that wall under any circumstance, even knowing how to do it. Not enough clear space to make it look right.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 05-08-2015, 07:33 AM   #4
Rewards Points: 4,794
this will be about as easy as filling a 4gal bucket w/5gal of water & not having it overflow onto the floor suggest you come up with another use or idea as this won't work
Installing new stone tile in my bathroom Axhammer Tiling, ceramics, marble 50 05-14-2014 05:00 AM
Decorative stacked stone falling off porch foundation Margaret J Landscaping & Lawn Care 2 05-06-2013 05:59 PM
Stone Tile Over Brick Fireplace - Did I Make a Mistake? Zach_C Concrete, Stone & Masonry 4 04-13-2013 11:38 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
