-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   How long to wait after patching concrete shower slab? (http://www.diychatroom.com/f105/how-long-wait-after-patching-concrete-shower-slab-162806/)
darsunt 11-10-2012 07:00 AM
I've opened up the slab under a shower to replace the trap. I planned to put gravel around the pipes and then put concrete to repair the slab. But I read somewhere you need to wait 7 days for the concrete to cure, keeping it wet all the time. I had not planned on this.
Oh'Mike mentioned using sackcrete. Does this material cure faster?
Also, the entire slab under the shower is slightly out of level. Should I try to fix this at the same time I fill the hole around the trap?
oh'mike 11-10-2012 07:06 AM
What are you going to do for the pan?
Premade pan or custom ?
I've never waited 7 days----one day---never had an issue----
darsunt 11-10-2012 07:21 AM
That wait is just what I read somewhere. If I can pour and work on it after 24 hours so much the better.
I plan either a shower pan or schluter kerdi pan. The slab is only slightly out of level, I don't know if it that will be critical.
oh'mike 11-10-2012 08:19 AM
Typically a bed of masons mortar is placed under a new pan to ensure a solid base---so some leveling can be done at that time-----
redman88 11-12-2012 12:35 PM
out of level in what direction? toward the drain or away from it?
