How Important Is Gravel? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree7Likes
Old 12-26-2016, 07:59 AM   #1
Rewards Points: 16
How important is gravel?
I am building a concrete pad. It will be about 10' by 20' and 4" thick. I plan to level the dirt and compact it. Install wire in the concrete. So what is the purpose and do I need a 1" gravel layer?
mhhickma is offline   Reply With Quote
Old 12-26-2016, 08:10 AM   #2
Rewards Points: 1,684
Re: How important is gravel?
No, you don't need gravel. Gravel doesn't compact and you don't need plastic either, but the compaction must be correct.
Old 12-26-2016, 08:14 AM   #3
jlhaslip's Avatar
Rewards Points: 2,812
Depends on where you are planning to pour the slab, what the soil conditions are like, whether there is water that might be an issue, what is your frost level, how hard the base is compacted.
What is the slab going to hold? A building or shed? A Patio for a BBQ? A garage and vehicle?
joecaption and Mrbuilder like this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-26-2016, 08:21 AM   #4
ZZZZZ's Avatar
Rewards Points: 2,748
The purpose of the gravel is to help with drainage, but a lot depends on where you live, the soil conditions, frost/freezing, etc.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 12-26-2016, 08:24 AM   #5
Rewards Points: 16
Going to be in Birmingham Alabama, pad will store Bee Keeping equipment and be enclosed inside a roof/wall.
Not sure about compacting dirt.
Old 12-26-2016, 08:27 AM   #6
Rewards Points: 16
If I have good compacted dirt could I probably skip the gravel?
Old 12-26-2016, 09:00 AM   #7
joed's Avatar
Rewards Points: 13,340
1" layer of gravel isn't going do much. It will just compact into the soil.
Old 12-26-2016, 09:54 AM   #8
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 176
Lightbulb
If MH," it'll be under a roof, wall" as you say sir, I would grade the space, lay 2" 3/4"stone, place 4mil poly on area and pour it. Seems to me you're not exactly sure what you will do with it after it's poured !! That being the case, I wouldn't want moisture wicking through the slab I just poured and stored important materials in the shed I just built !!
Just sayin'
" It's ok if you're not sure, find someone who is"
Mrbuilder is offline   Reply With Quote
Old 12-26-2016, 10:52 AM   #9
Yes, you can skip the gravel, it needs to go into the mix to make concrete , and compact the dirt a minimum of 2 ft. beyond the pad / building line. Moisture doesn't wick up through concrete. That moisture people see on top of a concrete pad / slab, in the parking lots and their walks is surface condensation.
Old 12-26-2016, 10:54 AM   #10
Rewards Points: 16
Thanks everyone. The are I am putting the slab is very narrow and has a slope. Thus adding 2 extra feet of dirt outside pad is tough. So I plan to build a cinder block wall to hold the dirt in.
Old 12-26-2016, 11:25 AM   #11
hkstroud's Avatar
Rewards Points: 2,046
The purpose of the gravel is to replace any disturbed soil. It is much easier to scrap out any disturbed soil and replace it with gravel than it is to compact soil. To compact soil it has to be done in increments. About 2" increments if compacting manually. And the soil moisture content must be correct.
Just simpler, easier and cheaper to back fill with gravel.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-26-2016, 11:37 AM   #12
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 176
you're right SS, no wicking, was just being dramatic. as for the stone, I think pouring w/o stone is asking for water runoff trouble, especially if walls are added. but that's just me.
just sayin'
Msradell likes this.
Old 12-26-2016, 05:54 PM   #13
Concrete & Masonry
Rewards Points: 620
I wouldn't skip the gravel, and generally speaking, we use a minimum of 4" under any concrete flatwork we pour. One of the main reasons is that there is generally more than 4" of topsoil/organic material that needs to be removed, so you generally need to import some kind of filler. You might as well use something that's easy to work with, compacts well, drains much better than soil, and is relatively cheap.
As or wicking, concrete undoubtedly can wick water or several inches, or more. The distance it can wick is often arguable, but the fact that it is not water proof and can wick water is not.........
KC_Jones and Al_Amantea like this.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
stadry (12-29-2016)
Old 12-26-2016, 06:27 PM   #14
Registered User
Rewards Points: 526
If you add walls and a roof, which block the wind that removes the moisture coming from below, be sure to add a vapor barrier plastic that retards the moisture vapor. The gravel layer stops capillarity of moisture, gives a reservoir for liquid moisture and minimizes shrinkage stresses and cracking; http://www.wbdg.org/systems-specific...ms/floor-slabs
The poly should be under and around the thickened footing perimeters, especially between any retaining walls abutting it to stop capillarity; https://buildingscience.com/document...059-slab-happy
Be sure to add some conduit in a slab/wall for future electrical work.
Gary
Msradell and Mrbuilder like this.
Old 12-27-2016, 07:01 PM   #15
Rewards Points: 3,730
Totally agree with what jomama45 said.
https://www.concretenetwork.com/vapo.../moisture.html
Canarywood1 is online now   Reply With Quote
Rainwater runs down road into driveway washing out gravel skobydog Concrete, Stone & Masonry 31 07-23-2015 10:59 AM
Landscape fabric under gravel driveway? jpsmith Landscaping & Lawn Care 15 12-09-2012 09:24 PM
Is gravel stop needed for a torch down roof? sanfranman12 Roofing/Siding 7 02-12-2012 02:57 PM
Gravel against foundation to stop water mnp13 Building & Construction 14 11-11-2011 02:22 PM
Wooden landscape tie retaining wall and gravel motherofthyme Landscaping & Lawn Care 1 07-30-2011 04:42 PM
