How To Fix Concrete CEILING?? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-24-2012, 12:40 PM   #1
How to fix concrete CEILING??
My house has a concrete porch that also serves as a ceiling for 2 small rooms in my basement. When I bought the house the home inspector pointed out a small cavity caused by rusting rebar.
So the time has come to fix it. I've removed all the loose concrete. Turned out to be more loose stuff than I thought.
I bought some Quik-Crete, thinking it would work like drywall spackle...but as many of you know (as I soon discovered), concrete doesn't exactly stick to the ceiling.
So, how do I patch this - and what can I treat the rebar with to keep it from rusting. I tried to find info online already and haven't had much luck.
Tim_ is offline   Reply With Quote
Old 05-24-2012, 03:37 PM   #2
Rewards Points: 3,824
Only thing you can do with the rebar is clean it up the best you can and coat it with red oxide paint and don't get it on the concrete.
The only thing i can come up with is to use a bonding agent,then try hydraulic cement trowled on in stages and keep it as dry as possible so it will stick.
Canarywood1 is offline   Reply With Quote
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Putting up a drywall ceiling...will need to drill into concrete. netvivi Remodeling 7 02-14-2010 06:13 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
Adding a ceiling!? My whole house is concrete! flipjarg Remodeling 9 12-02-2008 12:20 PM
