How To Finish My Paver Project??? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-03-2012, 04:03 PM   #1
How to finish my paver project???
Hello all,
So, I have completed a lot of the work required to build my 500Sqft paver patio. However, I had to use a retaining wall around it because the slope of the area was more than the slope for the patio. I used Basalite classic retaining wall block and had the bright idea of using the lip on the block to hold in all the perimeter pavers. I also used crusher fines, aka breeze, for the entire base and am thinking about using it all the way up to the pavers and not using sand.
I am not real happy of how this is all shaping up. I did a "paver test bed" with the landing on the patio (see pic). I found that the pavers that are not resting over the retaining wall block are sinking in more than the ones resting directly on the block. The sand for the cracks is spilling out of the perimeter and it is impossible to adjust the pavers resting on the block since there is no wiggle room.
My questions are:
How should I proceed?????
Should I use a sand layer?
If so, should I extend it over the retaining wall?
Any help would be greatly appreciated!
Also, here is a link to a quick video of it...
How to finish my paver project???-img_0998.jpg   How to finish my paver project???-img_0999.jpg   How to finish my paver project???-img_1001.jpg
kyle79 is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
How to remove paint but preserve original finish? Indyguy Painting 4 07-15-2009 01:36 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
