How To Fill 1" Joint In Concrete Driveway? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-04-2013, 12:22 PM   #1
How to fill 1" joint in concrete driveway?
What do I use to fill an extra large 1" joint between sections of concrete in my driveway.
It has a plastic backer rod inserted in the gap but other than that it's just dirt. It seems like any kind of concrete filler would easily crack.
walkman is offline   Reply With Quote
Old 07-04-2013, 01:11 PM   #2
joed's Avatar
Rewards Points: 11,560
Backer rod and polyurethane caulking.
Old 07-04-2013, 04:35 PM   #3
40 year old house -- do you think there was caulk in the joint originally and it's just worn out over time?
Old 07-04-2013, 06:45 PM   #4
joed's Avatar
My guess would be there was some sort of divider strip like wood or tarred expansion joint material.
Old 07-04-2013, 08:10 PM   #5
Rewards Points: 4,450
if i knew where in no ga, i could stop by & seal it on the way to ride the dragon
that ' plastic backer rod ' may be what's commonly call'd a ' zip strip ' but, from what i've seen, no one zips off the top & seals the joint,,, izzit like the stuff you'd see on pool decks ?
nevertheless, closed cell backer rod & 100% silicone no more than 3/8" thick,,, that's what we used on 78, 185, & 20 ' tool ' the stuff so it adheres well to clean joint sidewalls
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 09:07 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
