How Effective Is Concrete For Fireproofing? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-18-2013, 04:00 PM   #1
Rewards Points: 948
How effective is concrete for fireproofing?
I have a large steel box and a small steel safe.
What I want to do is fasten the box to the concrete floor, put the safe inside it, and put fireproofing around it inside the box to protect the contents from a fire.
I planned on using fiberglass, but then securing the safe to the box will be a problem. If I pour concrete in, it will both secure it, and fireproof it (not to mention making it too heavy to carry away...). Of course that is assuming that concrete is effective at fireproofing.
So, is it? Is there any special type to use that would be readily available in a small quantity?
Yeah, I could have just bought a fireproof safe, but the ones that also offer burglar protection are very expensive; the box and safe were really cheap.
Toller is offline   Reply With Quote
Old 08-18-2013, 06:06 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
Any kind of concrete has far better fire resistance than the worst, which is fiberglass. Your biggest problem will be the fire resistance of the safe and especially the door.
Dick
concretemasonry is offline   Reply With Quote
Old 08-18-2013, 07:01 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 812
Just use a few layers of drywall....5/8" type X. A single layer is rated at 1 hour. Put 3 layers around it and should be good.
Important point....interleave/overlap the corners.....and....limit access to the door. If you allow side access, then someone has room to get a crowbar in there.
Old 08-18-2013, 08:15 PM   #4
Rewards Points: 2,630
You can likely find some refractory concrete that has a high maximum temperature limit, but if your house burns to the ground, is it really important that the floor has no cracks? Seems you really just need insulation so that the contents of the safe don't burn to a crisp if the safe is sitting in a raging fire for an hour. The R value of concrete is not much, so the insulation around the safe will have a greater effect. I think fiberglass has a maximum service temp under 1000 degrees. But that might be enough. Check out rockwool insulation also --- it has a higher max temp rating. It is also available as rigid board, which might be more convenient if you want to sit a safe on it. But the rigid board is likely to be harder to find.
SPS-1 is offline   Reply With Quote
Old 08-19-2013, 02:27 PM   #5
Rewards Points: 948
I thought perhaps different cements had different R values.
I won't be able to fit anything rigid in the box around the safe, so drywall is out. Besides, the drywall won't secure the safe to the box, and burglary is more likely than fire.
I have my tax returns and such in a firesafe, but could open it in a couple minutes with an axe. But if anyone really wants my tax returns, I guess they are welcome to them.
Old 08-19-2013, 02:51 PM   #6
Rewards Points: 252
My wife works as a fire investigator, so she comes across safes quite often. Your safe may be fireproof, but is it heat and water proof too?
shazapple is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 05:15 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
