How Does One Use Fluted Nails? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-16-2013, 06:39 PM   #1
Rewards Points: 1,062
How does one use fluted nails?
People,
I have different lengths- 1", 2", etc. I understand these are made of hardened steel. Does this mean one can simply hammer away into a concrete slab? Predrilling nesessary? man, if not, I cant imagine slamming a 3 lb mallet onto these nails and someone not gettiing hurt........
Im hoping to use these to secure a steel L bracket into garage slab floor.......
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-16-2013, 06:45 PM   #2
DIY staff
Rewards Points: 7,174
Yep---using a non hardened hammer like a masons hammer or 2 pound maul---drive them in--wear a leather glove and goggles.
Most people use Tapcon screws for a job like that----or a 22 cal. stud gun---
Those are best used to nail in a board --so the wood holds the nail straight---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
noquacks (03-16-2013)
Old 03-16-2013, 07:04 PM   #3
OK, now, can this fluted nail crack the concrete?
Old 03-16-2013, 08:18 PM   #4
Rewards Points: 13,964
Sure can. What is this angle suppost to do for you?
Old 03-16-2013, 08:45 PM   #5
Rewards Points: 3,718
Your better off using Tapcons.
Canarywood1 is offline   Reply With Quote
Old 03-16-2013, 08:58 PM   #6
Rewards Points: 960
The advice to use tapcons or a plug & screw should be heeded.
I have only used the masonry nails in green concrete and if they were the cat's arsch, tapcons and what not would not exist.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Old 03-16-2013, 09:05 PM   #7
Using the right load a Ram set will go right through the angle and the concrete in one shot.
But I agree long larger Tap Cons will work fine.
Old 03-17-2013, 08:34 AM   #8
Thaks, people. The angle is supposed to support a garage post in case a car accedentally "bumps" into the post. Quite a force.
tap cons are good, its just such a pain to pre drill. I tried with hammer drill, and drill bit is soooo stubborn to cut. I will probably abandon fluted idea....
Old 03-17-2013, 09:46 AM   #9
Rewards Points: 960
Whenever I drill in concrete, I have a spray bottle of water and I keep the hole wet. I'll take every advantage I can get.
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 12:26 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 10:05 PM
sinking fluted masonry nails ajtool General DIY Discussions 3 09-02-2010 03:58 PM
