Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-15-2012, 04:50 PM   #16
How do you keep your forms from sticking to the concrete?
Originally Posted by jomama45 View Post
I told you a number of times two different ways to do it, and I'm not simply guessing at it either. I've built a number of waterproof concrete assemblies through the years, including many septic tanks, and can tell you that the joint between the two pours is almost guaranteed to leak..............
Are you talking about using 'water stop'? I didn't know what that was, was hoping the waterproofer I was planning on using would keep the joint from leaking.
Can you better explain what your saying to do? Are you talking about using this on the foundation before I pour the walls? http://buildingmaterials.cetco.com/L...2/Default.aspx
tibberous is offline   Reply With Quote
Old 10-15-2012, 04:56 PM   #17
Btw, this is what I was planning on using to waterproof the tank:
http://www.thehardwarecity.com/produ...int-5g/0003507
Old 10-15-2012, 05:37 PM   #18
Concrete & Masonry
The first link is what we refer to as "voclay" and will work, but you need the adhesive to glue it down, or you can nail it down.
AN easier option would be to look into "Sikaswell S-2", but I think it only comes in a "sausage" tube and you'd need a bulk gun to put it on.
I actually meant a pvc ribbed waterstop (search for WR Meadows waterstop) when I used that term. This would be poured right into the slab and extend into the walls, but ideally, it should be seemed together, or at least try to glue it........
The second link is nothing more than a band-aid IMO, and will need to be re-coated every few years. You could use a far superior product once, for a fraction of the price, and have far better results IMO, but you're still going to have to hope that the concrete itself doesn't leak through, which is why I offered the other, foolproof method: encapsilating the entire thing in a rubber membrane.........
jomama45 is online now   Reply With Quote
Old 10-15-2012, 05:39 PM   #19
Bombastic Idiot
notmrjohn's Avatar
You need rebar, and unless you can do it all in one pour or shoot gunite, jomama and concretemasonry are gonna say, "Told ya so" 450 gallons of water weighs almost two tons. All that weight is going to be pushing down and out. The deeper the tank of same size the more pressure at the bottom sides.
If you got to Farm and Ranch Supply Store or online, you can find a 4'X8'X2' deep stock tank that holds around 470 gallons. Various sizes; shapes, round, oblong, eliptical; materials, metal, plastic, resin, fiberglass are available. Pillows, or giant water bags, are available at military surplus outlets.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
vibrating concrete externally via the forms DIY1 Concrete, Stone & Masonry 13 07-01-2012 12:12 PM
Sidewalk Concrete Forms next to house jimsi Concrete, Stone & Masonry 2 05-25-2012 11:30 AM
Concrete forms tickifrog46 Building & Construction 2 10-07-2011 11:10 AM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 10:24 AM
