Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-23-2012, 09:46 AM   #1
nkuclo's Avatar
How do I re-paint a stamped concrete patio?
We have a stamped concrete patio that has been painted once. The paint is chipping off. How do I prep for a new paint job?
nkuclo is offline   Reply With Quote
Old 06-23-2012, 11:34 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Probably the simplest plan would be scrub it with an abrasive pad....
The Best way would probably be sandblastin' it.... clean up, 'n damage control issues aside...
Old 06-23-2012, 01:07 PM   #3
nkuclo's Avatar
You've kind of scared me Is this going to be difficult. Do we need to "sand blast" or can we just "power wash"?
Old 06-23-2012, 01:08 PM   #4
A stamped concrete deck or pation should have been stained not painted.
Paints just not going to hold up.
Old 06-23-2012, 01:12 PM   #5
nkuclo's Avatar
I believe the color was originally in the concrete when it was poured. We bought the house with the stamped patio. Then we needed a new pad put in and they could not match the color, so they painted the entire patio. What do we do now?
Old 06-23-2012, 01:26 PM   #6
You could try pressure washing first to see what happens, but to get it all off you may have to blast, using crushed walnut shells may work best for a media.
Old 06-23-2012, 02:28 PM   #7
nkuclo's Avatar
Thanks. Where can I get that many crushed walnut shells?
Old 06-24-2012, 02:52 PM   #8
Scroll all the way down to the bottom of the page.
http://www.kramerindustriesonline.co...FQSynQodklfDzw
Canarywood1 is offline   Reply With Quote
Old 06-24-2012, 03:00 PM   #9
Renovations contractor
Bonzai's Avatar
There are specific products for painting patios which are typically a kind of epoxy coating designed to stand up to heavy use and weather. Do you know what product they actually used?
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Removing Adhesive and Paint from Concrete onthejob Flooring 4 03-29-2012 11:11 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
