Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-18-2012, 03:32 PM   #1
Question
How do I fix my driveway?
My driveway is solid underneath, but the top layer is cracked in places, and others the top is chipped off. Other parts look like it could use a cosmetic upgrade. it is 30 years old.
A person on another forums told me to use the quikrete resurfacer, but all I have read about it, with very few exceptions, is bad. The chipped areas in my driveway are at least 1/4" to 1/2". It varies. Maybe not 1/2". That's kind of big. These areas will need to be filled in before any kind of top later is added or complete.
So, I was hoping someone could tell me how to fix my driveway if the resurfacer product is no good. Do I just use regular concrete?
This is the stuff that's not good, supposedly. I even read that on here with the search:
http://www.youtube.com/watch?v=lkl3bY7Z88k&feature=plcp
Thanks.
Learning2Diy is offline   Reply With Quote
Old 07-18-2012, 04:38 PM   #2
MarginallyQualified
Asphalt?
Fill the existing cracks to smoothness (perhaps expand some and then fill); then coat .
Old 07-18-2012, 05:30 PM   #3
It is a concrete driveway.
Old 07-18-2012, 05:33 PM   #4
It can be covered with asphalt.
personally I have never had bad results with resurfacer, other than the cost.
framer52 is offline   Reply With Quote
Old 07-19-2012, 07:11 PM   #5
Dont use a quickcrete product. Find a concrete supply company. They will carry a more substantial product. Might pay a little more but it will be well worth it. You have to grind out ALL the cracks to at least 1/2" to be able to get enough new mud in there. 1/4 is to small.
http://www.whitlockbros.com/services.html
Heres a link to similar products you might find helpful.
TRUEPRO is offline   Reply With Quote
Old 07-20-2012, 09:38 PM   #6
At 30 years your driveway is at the end of it's useful life,either replace it or have it top coated with blacktop,and get another 15 or so years out of it.
Canarywood1 is offline   Reply With Quote
Old 07-21-2012, 12:35 AM   #7
Try a spec smooth or repcon v/o 928. Both are good products. Spec patch will be the most costly but is a brilliant product. All are spec Chem products. If you can't find a dealer near you that carries the product, try Stan Houston.com.
Sent from my iPod touch using DIY Forum
slimcutta is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 7 05-06-2012 11:43 PM
Driveway + Walkway buildup question r0yal Landscaping & Lawn Care 2 03-24-2012 09:42 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 08:07 PM
