How Do I Cut An Outside Soldier Border Edge In Granite Paver? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-24-2013, 02:48 PM   #1
How do I cut an outside Soldier border edge in Granite paver?
I know this is probably really easy, but I have a 3cm(1.25") granite I am using on my deck. I decided to use an outside soldier edge to nicely frame the mini french pattern I am using. I have two outside edges to build around a bay window. How do I acurately measure and cut this outside edge? I'd like a 45 cut coming straight out of the angle. Because of the color granite I used for this section of soldier, I have one shot at getting it right, so figured I would ask first. Thanx.
peakcelln is offline   Reply With Quote
Old 05-24-2013, 08:00 PM   #2
Rewards Points: 4,538
you're right, its easy just make a cardboard pattern, grab a 4" grinder w/diamond blade, then cut away,,, might have to cut from top & bottom as a 4" blade will only saw 1" deep
Old 05-24-2013, 09:23 PM   #3
DIY staff
Rewards Points: 7,174
A 10" wet saw (tile saw) will also work well----
Tags
granite paver , outside edge , soldier
Poor Quality Granite Installation - HELP! NCRod16 Kitchen & Bath Remodeling 7 10-20-2012 11:04 AM
Glass/Natural stone border freshstart Tiling, ceramics, marble 2 08-07-2011 04:25 PM
Using granite & laminate for kitchen Jetboy55 Remodeling 5 08-10-2008 10:56 AM
Driveway border filled with "wire grass" Beth777 Landscaping & Lawn Care 10 07-21-2008 11:00 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
