How Deep Should I Dig For 20"Hx7"W Concrete Wall? - Concrete, Stone & Masonry - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-21-2014, 09:34 PM   #46
Msradell's Avatar
Rewards Points: 262
Originally Posted by almazon View Post
It looks like concrete guys are expecting to see a whole crew here.
That makes me worry. I told them I will be the only one.
Is that a problem? Will I be able to handle it myself?
Either they are you are going to be in for a big surprise, hopefully it will be them!
Do I have to use a concrete vibrator?
You don't have to have one but it would certainly make the concrete flow smoother into the form and reduce the possibility of voids. It will also probably give you a better finish of the concrete against the forms.
Msradell is offline   Reply With Quote
The Following 3 Users Say Thank You to Msradell For This Useful Post:
beenthere (04-22-2014), BigJim (05-20-2014), kwikfishron (04-21-2014)
Old 04-24-2014, 03:55 PM   #47
Concrete & Masonry
Rewards Points: 620
Sooooo, how did it go?????
jomama45 is offline   Reply With Quote
Old 04-24-2014, 10:15 PM   #48
Rewards Points: 119
LOL! It went great! IMAO!
Ok guys,
This is what I got!
I calculated 4.53 cubic yards and ordered slightly more (5 cubic yards). When the truck finished pour I ended up slightly short and had to rent a Mixer and buy another 16 bags (5000) from local Home Depot.
After all form stood well on both LOWER...
...and HIGHER sides
The only issue is that, because I was working alone (well not exactly - my wife helped me) I missed couple of spots and did not finished it properly on top.
For this purpose I got Hydraulic Water-Stop Cement by Quikrete AND need your input on this:
Another question is when I can start removing wood?
almazon is offline   Reply With Quote
Old 04-25-2014, 09:43 AM   #49
Rewards Points: 119
Guys,
Still, can I start removing the wood?
My sixth sense telling me YES, but I just wanna make sure...
Old 04-25-2014, 12:28 PM   #50
Concrete & Masonry
Rewards Points: 620
Guys,
Definitely safe to strip it now.......
Old 04-28-2014, 08:53 PM   #51
Rewards Points: 119
Ok, guys,
My agenda slightly changed since I am NOT planning to put Chain Link Fence on top of this Concrete Wall that I just poured. Instead I want to go with Concrete Block Wall. Thanks to the guy from Building Dept who gave me this idea. Then most likely I am going to finish it with Stucco or something.
When I poured concrete I did not really finish it on top and its NOT really leveled. So now I want to finish it with Hydraulic Water-Stop Cement (Quikrete) to make it more leveled before laying out Blocks.
That's why I did not remove the wood yet...
Is this stuff Ok to do it?
Do I have to prepare (finish, level, etc) it this way?
Or I will be Ok starting with Blocks just like that?
Just make sure that first row gonna be leveled?
Thank you in advance,
almazon
Old 04-28-2014, 09:18 PM   #52
Msradell's Avatar
Rewards Points: 262
If you are going to just put block on top of it there's no need and leveling at 1st. You can just pulling string line for the top of the 1st course and level the blocks with the mortar bed. If fewer types of material that are involved the better.
The Following 2 Users Say Thank You to Msradell For This Useful Post:
concretemasonry (04-28-2014), oh'mike (05-20-2014)
Old 04-29-2014, 03:53 PM   #53
Concrete & Masonry
Rewards Points: 620
You're changing the entire scope of the project now. Before, it was a light fence, now it's a block wall it's supporting? Now, with the change, and your environment, as well as it's location next to a sidewalk, I'd highly suggest you don't build a block wall on top of that with out frost protection...........
Old 05-08-2014, 10:44 AM   #54
Rewards Points: 119
Anyway, guys,
I removed the wood and this is what I got so far. I think its not THAT bad:
I decided to keep existing Chain Link gates for now:
Need some finish in couple corners:
I think it will be enough support for Block Wall considering it goes in average 3' deep.
I am planning to use 6" Blocks (Wall itself is 8") and flush it with Inner wall giving some space for finishing on Outside.
This is what I am talking about when I say its not really leveled:
Do you think I will be able to fix (bring to level) it at 1st course of Blocks with the Mortar Bed?
almazon
Old 05-08-2014, 10:56 PM   #55
Msradell's Avatar
Rewards Points: 262
That should be very simple to correct on the 1st course of block!
Old 05-11-2014, 03:30 PM   #56
Rewards Points: 119
Hey guys,
Thanks a lot all for helping me with this project!
I don't think it would be possible to do it without your helpful advices!
Its time for my next Laying Out Concrete Block Wall project!
Thanks again,
almazon
Old 05-12-2014, 04:42 PM   #57
Concrete & Masonry
Rewards Points: 620
I realize you've likely already made your mind up, and there's no way to change it, but I still think this is a bad idea. Sure, you have a few feet of wall in the ground, but is it set on a spread footing, meaning a footing that's about 8" thick and twice the width of the wall? Is the below grade portion of the wall formed smooth on both sides to deter frost "picking" against the wall? Is the wall isolated from the flatwork surrounding it with proper material? Unfortunately, I believe the answer to every one of these questions is "NO", and what you're trying to do goes against all "best practices" in the construction of a foundation and wall in a frost zone............
Old 05-17-2014, 08:34 AM   #58
Rewards Points: 119
What's the worst that could happen?
Old 05-20-2014, 05:59 AM   #59
DIY staff
Rewards Points: 7,174
Worst case? The wall will start to lean---
I'm not a mason by anyone's estimation---so take this with that in mind.
Could you build a short block wall and then extend the height wiith a light er privasy screen?
Old 05-20-2014, 09:50 AM   #60
Ole Wood Worker
BigJim's Avatar
Rewards Points: 512
If that were mine I would be checking with my insurance people to see what their specs are. It would be bad to go ahead and build a wall that they will not insure, then have to take it down.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 08:14 PM
Exterior wall on concrete pad - waterproofing under wall? (Illustration included) JustADoc Building & Construction 12 08-18-2011 05:07 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 08:56 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
