How Deep Should I Dig For 20"Hx7"W Concrete Wall? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-15-2013, 04:51 PM   #16
"You can do anything"-Mom
brockmiera's Avatar
Originally Posted by Live_Oak View Post
"So for this reason I decided to dig the Fence out, slightly move it away from sidewalk and place it on top (or inside) Poured Concrete Wall"
Guys, the fence will be "inside" the concrete wall, meaning that it's what's anchoring that fence. With no mention of fence posts going below frost line. With the fence merely anchored in a shallow not below frost line concrete "wall", it's going to need to be able to stand up to a winter wind pushing on it's ice filled privacy mesh. And that's why I said that the entire structure should go below frost level.
I've never seen fence posts be required to go below frost. Again they are allowed to float. Whether he places them inside or anchors them to the top it should be fine.
brockmiera is offline   Reply With Quote
The Following 2 Users Say Thank You to brockmiera For This Useful Post:
Msradell (10-15-2013), oh'mike (10-15-2013)
Old 10-17-2013, 09:22 PM   #17
Rewards Points: 119
Thanks guys for ALL of your responses!
At this time all I can say is I am not planning to go below frost line.
I will continue digging this weekend. Probably up to 18".
Of course there will be rebars and draining involved. I got very nice Black & Decker books...
I already called one of our local Ready Mix company. They gonna charge me APPROX $198 per sq yard of PS4000 (or whatever), if its gonna be just 1 yard. More yards cheaper.
I calculated 1 yard is what I need for this side. Most likely I will need another sq yard for another side.
That's all I can say for now. I will keep you posted!
Thanks again,
almazon
almazon is offline   Reply With Quote
The Following User Says Thank You to almazon For This Useful Post:
oh'mike (10-17-2013)
Old 12-04-2013, 12:51 PM   #18
Rewards Points: 119
Hello guys,
Remember me? Here's an update:
1. Wall is going to be 8". Not 7" as previously planned.
2. After leveling everything out starting from the lowest point of the wall on other side (9") I ended up with 29" at highest point of the wall. Not 20".
3. I dug for at least as same as height of the wall.
4. I banged Vertical rebars approx. 4-6" into the ground, 2" from the top of the wall and 16" from each other.
5. I also installed Horizontal rebars 8" from each other.
6. I finished building both Outer and Inner walls of the Form (shown covered temporarily with corrugated plastic)
7. On the bottom these walls are holding to each other with 1/2" x 12" Stainless Steel rods installed 4' from the bottom and 3' apart.
8. Each of these rods go through 1.25" x 8" PVC pipe that will stay there after concrete will be poured AND served as part of drainage.
Now, I am working on Stakes, Diagonal and Horizontal Bracing.
I have 2 questions:
1. What would you recommend to use to hold Form Sides together?
2. Will 16 gage wire loops do the trick?
3. Or should I go with the rods?
Also:
4. If the form will be secured on one side can I skip securing it on another side?
Thank you in advance,
almazon
Old 12-05-2013, 06:08 AM   #19
Rewards Points: 4,538
missed this thread,,, we work'd on the richmond off the outerbridge so, if i recall correctly, you don't get any appreciable frost in staten is - same as e nj, maybe 6" at the most,,, btw, what an amazing formwork for a diy'er
you ask'd 4 ?'s, not 2 i'd wire the forms w/tie wire - 24" spacing on the top row & 12" on the btm - drill a 1/8" hole, run wire thru, & secure to nail on the exterior - EACH side !
good luck !
The Following User Says Thank You to stadry For This Useful Post:
almazon (12-06-2013)
Old 12-05-2013, 05:24 PM   #20
Rewards Points: 3,426
I agree with IRC about more ties on the lower part of the wall,but the upper part just nail some 2x4 across the top of the forms,save you from a lot of drilling.
Canarywood1 is offline   Reply With Quote
Old 12-05-2013, 05:50 PM   #21
Lord knows he's used to 2 x 4's by now,,, good catch, woody
Old 12-06-2013, 11:51 AM   #22
Rewards Points: 119
good luck !
Thanks IRC,
I am planning to do a PLENTY of wiring at both TOP and BOTTOM at 16" spacing.
Old 12-06-2013, 12:08 PM   #23
Rewards Points: 119
Thanks Canarywood1,
I don't mind drilling!
Old 12-06-2013, 02:27 PM   #24
Originally Posted by almazon View Post
Thanks Canarywood1,
Your call!
Don't forget to use a release agent on the interior of the forms.
Old 12-08-2013, 03:22 PM   #25
Rewards Points: 119
Your call!
Now, that's interesting, since book suggesting Vegetable Oil.
What would you recommend?
Old 12-08-2013, 04:04 PM   #26
get a couple gallons of diesel & an old broom,,, if you use vegetable oil, it might attract rodents from the fresh kill btw, not even sure diesel's legal anymore but you are in staten island
Old 12-08-2013, 06:53 PM   #27
As IRC said #2 diesel would be my choice,has more wax in it than #1.
Old 12-09-2013, 12:18 AM   #28
Rewards Points: 119
Another issue with my project is that Winter is here. As of right now whole form is covered with 4 mil plastic. Of course I will look into mild days to finish wiring and securing the form, but...
How long do you think I will have?
Old 12-09-2013, 04:50 AM   #29
' How long do you think I will have? ' to what,,, finish it ? have any chance of finding conc blankets ? you can rent them from gamka in edison but you might also find 'em on s.i.,,, w/blankets, i'd pour lo-slump conc in the am on a 40f & rising day when nite temp won't drop below 30f & cover w/conc blankets for a wk - unfortunately, this is all based on weather in my head making off the previous ' iffy ',,, some pours we'd call 4 conc the next am & cancel when arriving @ 0-dark-30 that's conc ' life ' - best !
Old 12-09-2013, 08:35 AM   #30
Rewards Points: 119
Thanks irc,
What I really meant to ask is how long do you think I will have for the form to withstand this weather before the pour?
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 09:14 PM
Exterior wall on concrete pad - waterproofing under wall? (Illustration included) JustADoc Building & Construction 12 08-18-2011 06:07 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 11:14 PM
