How Deep Do I Dig Footing? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-08-2012, 07:02 PM   #1
how deep do i dig footing?
I am building a block front porch that is 74 in wide and 16 ft long and 2ft high, do I need to fill the inside with dirt or with concrete?
ghom is offline   Reply With Quote
Old 08-08-2012, 07:08 PM   #2
All safety precaution will be maintain
Old 08-08-2012, 07:16 PM   #3
Rewards Points: 13,458
Your local building dept. will tell you how wide and how deep it needs to be and how many pieces of rebar your going to need.
Ever done this before? I'm guessing not because of the questions.
It sure would be a great job to hire out.
Old 08-08-2012, 08:41 PM   #4
DIY staff
Rewards Points: 7,174
Your location is needed to get a good answer---frost line depth is needed to help you.
Old 08-08-2012, 09:02 PM   #5
ghom
I am located south east arkansas at the border of arkansas and mississippi .
Old 08-08-2012, 09:05 PM   #6
Concrete & Masonry
Rewards Points: 548
You likely have no frost line, so you need to excavate through all "organic" soil and down to solid soil. The inside should be backfilled up to the bottom of the concrete with either gravel compacted in short lifts, or a clear stone with no fines in it.............
jomama45 is offline   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
ghom (08-08-2012)
How to pour a replacement piece of footing? Homerepairguy Concrete, Stone & Masonry 2 02-29-2012 12:51 PM
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 01:39 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 08:50 AM
Beam base support footing, how deep? gante Building & Construction 4 03-20-2009 11:11 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
