How To Clean A Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-29-2013, 11:55 PM   #1
Rosemarys's Avatar
How to clean a chimney
Hello, just purchased a new home and need to find out all the information I need to sweep and clean the chimney myself. Is anyone a pro at this and can give me some info? Costs? Materials? Cheaper ways? Time consuming? Haven't moved in yet but would like to be prepared. Thank you! =D
Rosemarys is offline   Reply With Quote
Old 01-30-2013, 12:16 AM   #2
Rewards Points: 14,014
I would not do it.
Hire a sweep and there not only going to have all the equipment to do it right and not leave a mess but there going to be inspecting it for cracks or anything else from top to bottom that might cause a roof leak or fire.
Old 01-30-2013, 01:35 AM   #3
Bumpr1080's Avatar
Are we talking a traditional chimney or a simple metal piping stack?
The circular jobs (from wood stoves) are very easy to clean.
Bumpr1080 is offline   Reply With Quote
Old 01-30-2013, 06:15 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,... At a bare minimum ya need a ladder that'll get ya to the top of the chimney, a brush of the proper size, 'n enough handle sections for it to reach to the bottom of the flue...
Old 01-30-2013, 12:00 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
There are kits and tools that will let you do it yourself, but for safety's sake I would have a professional do it the first time. Like Joe said, a professional can inspect it for problems or defects that your home inspection wouldn't catch.
Look for someone licensed and experienced. A place that sells and installs fireplace inserts is a good place to start your search.
Old 01-30-2013, 11:59 PM   #6
Rosemarys's Avatar
Thanks for all the responses -
clean chimney jckkcj General DIY Discussions 13 08-25-2012 05:56 PM
gas hot water tank venting in chimney w no furnace... dbldee20 HVAC 5 02-25-2011 08:21 AM
Chimney leaking AgentW Building & Construction 43 12-23-2010 10:20 PM
Decorative chase for masonry chimney and radon vent? Badfish740 Building & Construction 1 05-03-2010 06:51 PM
Where a wall meets a chimney joelbuckley Carpentry 12 11-13-2008 03:19 PM
