How To Carefully Remove Brick Raised Heath - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-24-2013, 07:16 AM   #1
Rewards Points: 37
How to carefully remove brick raised heath
I need to rebuild a brick raised hearth for my fireplace and was wondering what the best way to demo the existing hearth: 1) Safely, and 2) without damaging the face of the fireplace, which is also brick. Are we talking chisel and masonry hammer? Thanks!
SoxFan44 is offline   Reply With Quote
Old 09-24-2013, 07:39 AM   #2
DIY staff
Rewards Points: 7,174
Yep----that's what works well-----
SoxFan44 (09-24-2013)
Old 09-25-2013, 06:13 AM   #3
Rewards Points: 4,656
an electric chipping gun works the same but does it much faster,,, IF you're worried about the f/p face, use a 4" grinder & diamond blade to saw an isolation kerf
The Following User Says Thank You to stadry For This Useful Post:
SoxFan44 (09-25-2013)
Old 09-25-2013, 08:27 AM   #4
Rewards Points: 37
Thanks guys. One more question, I'm going to rebuild the raised hearth (slightly smaller) and it's going to have a granite slab on top of it and stone veneer on the sides. Approx 18" x 48", 2" thick. Not sure what it weights but it's obviously heavy. What kind of structure am I going to have to build to rest this on? I was thinking about constructing something out of 2x6s, then putting 3/4" ply and cement board on the sides. Should I put plywood & cement board on the top as well? With this frame be strong enough for the slab? Thanks!
Old 09-25-2013, 08:41 AM   #5
IF what's supporting the hearth now is sufficient, i wouldn't think you need worry about what's underneath,,, your plan sounds fine BUT remember little people ( AND big people, too ) often have desires to sit upon hearths granite has little flexural strength so keep that in mind,,, no sense in expending all your time/$ only to see your fat brother-in-law sit on it then hear it crack
Remove Silicone Based Sealant from Brick markstg Concrete, Stone & Masonry 3 06-25-2013 05:12 PM
Remove Silicne Based Sealant from Brick markstg Concrete, Stone & Masonry 0 06-17-2013 11:26 AM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 02:22 PM
How to remove paint from brick beezee3 Remodeling 2 12-28-2005 01:38 AM
