-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   How to carefully remove brick raised heath (http://www.diychatroom.com/f105/how-carefully-remove-brick-raised-heath-187546/)
SoxFan44 09-24-2013 07:16 AM
I need to rebuild a brick raised hearth for my fireplace and was wondering what the best way to demo the existing hearth: 1) Safely, and 2) without damaging the face of the fireplace, which is also brick. Are we talking chisel and masonry hammer? Thanks!
oh'mike 09-24-2013 07:39 AM
Yep----that's what works well-----
stadry 09-25-2013 06:13 AM
an electric chipping gun works the same but does it much faster,,, IF you're worried about the f/p face, use a 4" grinder & diamond blade to saw an isolation kerf
SoxFan44 09-25-2013 08:27 AM
Thanks guys. One more question, I'm going to rebuild the raised hearth (slightly smaller) and it's going to have a granite slab on top of it and stone veneer on the sides. Approx 18" x 48", 2" thick. Not sure what it weights but it's obviously heavy. What kind of structure am I going to have to build to rest this on? I was thinking about constructing something out of 2x6s, then putting 3/4" ply and cement board on the sides. Should I put plywood & cement board on the top as well? With this frame be strong enough for the slab? Thanks!
stadry 09-25-2013 08:41 AM
IF what's supporting the hearth now is sufficient, i wouldn't think you need worry about what's underneath,,, your plan sounds fine BUT remember little people ( AND big people, too ) often have desires to sit upon hearths :yes: granite has little flexural strength so keep that in mind,,, no sense in expending all your time/$ only to see your fat brother-in-law sit on it then hear it crack :no:
