How Can I Change Stucco Color? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-20-2012, 01:15 AM   #1
How can i change stucco color?
I bought some stucco from home depot to fix some broken areas on the side of my house. The problem is the stucco is white and the side of the house stucco color is a dark gray.
How can i change the stucco color? can i use charcoal cement dye? Just play around with the mix until it looks good?
Cheers thanks.
jayinwww is offline   Reply With Quote
Old 07-21-2012, 03:00 PM   #2
Well i tried a few different cement colors but it didn't work well. The thing is every house on my block has this grayish brown color on their house. The stucco I bought is a white kind from home depot. Is their a dirt / sand base type stucco out there that matches this color that anyone knows about?
Old 07-22-2012, 05:09 PM   #3
Rewards Points: 502
You'll never get a good match because there will be no consistency in the type of mix or water content, for example.
Why not just paint the whole lot?
tony.g is offline   Reply With Quote
Old 07-22-2012, 05:23 PM   #4
Well i found out that stucco comes in white base and gray base. So gonna try to get the gray / brown base because I think it will match up perfectly. But I guess I will find out soon enough when i pick it up monday lol
Color change issue n0c7 Painting 7 03-05-2010 09:02 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Best way to change color at a round corner? SDG Painting 3 12-11-2008 06:27 AM
The hot white - reidentify (change color) jamiedolan Electrical 18 10-24-2008 02:50 PM
Need help with wall & carpet color scheme Cruciatus Interior Decorating 6 04-05-2008 01:50 PM
