Hollow Clay Brick - Need To Cut - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-01-2013, 01:46 PM   #1
Hollow Clay Brick - Need to Cut
See photos:
Tried using a small Coleman angle grinder with a diamond blade, but it would have taken all weekend to cut one block in half. For one thing the blade wobbled on the shaft.
These bricks aren't made any longer as far as I know around here - eastern Ohio. I need to cut just 3 or 4.
Should I just rent a REAL machine?
Thanks!
pilk00 is offline   Reply With Quote
Old 06-01-2013, 01:59 PM   #2
Photos
Old 06-01-2013, 03:03 PM   #3
Rewards Points: 3,370
You can pickup a 4 1/2" angle grinder at harbor freight for $15.00/$20.00 and a set of disc's come with it.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
pilk00 (06-01-2013)
Old 06-01-2013, 03:05 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
That or take it to Home Depot and have them wet saw cut it.
You will just have to rotate the block 4 times but if you set up the fence on the table, should be quick and easy and have a clean cut line.
The Following User Says Thank You to Windows on Wash For This Useful Post:
pilk00 (06-01-2013)
Old 06-01-2013, 03:24 PM   #5
Civil Engineer
Rewards Points: 4,522
You can cut this block using a circular saw and a diamond blade. The lowest cost diamond blades are about $15. Four cuts, you are done.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
pilk00 (06-01-2013)
Old 06-01-2013, 05:06 PM   #6
Rewards Points: 4,454
coleman makes an angle grinder ? had no idea,,, nevertheless, any small grinder w/4" diamond tile blade IS the tool,,, apron/vest stores sell 4" tile blades OR you can buy 'em off eBay from ' greens garage ' for $ 3 ea.
WOBBLING BLADE MIGHT BE A KILLER/MAIMER ! most likely reasons for the wobbles: 1, blade nut wasn't tight enough; 2, the blade was distorted; 3, blade's bent concave from not using the proper blade spacer behind the blade; or 4, shaft bearings are shot,,, normally those things spin @ up to 10,000rpm's,,, 1 broken segment can cut/tear like an m16's bullet - it'll tumble inside you !
The Following User Says Thank You to stadry For This Useful Post:
pilk00 (06-01-2013)
Old 06-01-2013, 05:12 PM   #7
I think I'll try the diamond blade for the circular saw first.
Good to know HomeDepot cuts brick. Nearest one is 30+ miles away though, so I usually go to the local Lowes.
I had ordered the diamond blade for the Coleman angle grinder online. Might have worked except for the fact that it wasn't the same thickness as the standard blade that came with the grinder, which has 4 holes in it corresponding to the tightening holes.
I switched to the standard disc and it worked pretty well, but wore down to nothing cutting through just one side of one block
Appreciate all your prompt helpful responses!
Old 06-01-2013, 05:17 PM   #8
Rewards Points: 12,868
Sounds like you were using a masonry blade not a diamond blade if it wore down.
Old 06-01-2013, 05:19 PM   #9
itsreallyconc, not using the spacer sounds right. I could see the need for one, but didn't know they were available. Does Lowes carry them?
Old 06-01-2013, 05:23 PM   #10
True. Is a masonry blade for cutting through mortar?
Old 06-01-2013, 05:30 PM   #11
all of our grinders use a backing plate placed over the blade spindle,,, then the blade then the blade nut,,, the only time we don't use 'em is when we put on cup wheels.
abrasive blades have largely been made irrelevant by diamond blade technology imn-s-hfo we do all out cutting w/dri-diamonds,,, all they're short cuts like yours
pilk00 (06-01-2013)
Old 06-01-2013, 05:47 PM   #12
Another Question
I think I have a very cheap angle grinder - that probably cost less than the diamond blade I bought separately.
You've sold me on dry cutting with diamond blades. In your opinion does it make sense to buy a diamond blade for my circular saw and do the job that way, or does this job really call for a good angle grinder?
thanks!
Old 06-01-2013, 06:01 PM   #13
call greenie rent a grinder
pilk00 (06-02-2013)
Old 06-02-2013, 05:45 AM   #14
Rewards Points: 582
Years ago we used to fill them with sand, as with clay pipes, and cut them with a really sharp chisel, using gentle taps with the hammer. Took a bit of patience, but the diamond blade has sent that method to the history books.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
pilk00 (06-02-2013)
Rotting Door Jamb - Basement Walls Made of Hollow Clay Brick pilk00 Concrete, Stone & Masonry 12 05-05-2013 09:09 PM
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 12:56 PM
Painting exterior brick - soft Mexican clay lucymiella Painting 3 11-04-2012 01:56 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 09:43 PM
