#1 |
holes in brick mortar
My brick house has several (many) little screw holes where former owners had a hose hung or a decoration on the house.
What do I use to fill these holes? thanks |
#2 |
holes in brick mortar |
#3 |
Post a picture.
Is it just gray morter? If so then just mix some up and put it on the holes. |
#4 |
There are a number of injectible products you can buy that will work fine that fit a standard caulking gun. I generally despise the stuff but even silicon will work for small holes.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to sdsester For This Useful Post: | Startingover (09-25-2012) |
#5 |
I never use them, it makes the flaw stick out to much.
#6 |
the holes are inconspicuous so my main concern is keeping insects or dampness out.
thanks. and it's a gray mortar that looks the color of concrete. In fact I need to buy a bucket of concrete patch so maybe I will use that. |
#7 |
Absolutely positively DO NOT use concrete patch. Please to god do not do that.
Completely different product that will look terrible. I cant tell you how many homeowners i have came behind after they destroyed there brick veneer with concrete patch and had to acid wash, grind and tuck point after. Nightmares i tell ya. My suggestion, grey silicone. Keeps the water and bugs out. Def wont match but its better then holes. OR The right way would be to hire an out of work bricklayer, which im sure there are plenty out there, and pay him 50 bucks to do it right. |
| The Following 2 Users Say Thank You to TRUEPRO For This Useful Post: | sdsester (09-26-2012), Startingover (09-29-2012) |
#8 |
OOPS,
Truepro, thanks and just in time. Will go to Home Depot tomorrow for grey silicone. thanks |
| Display Modes | |
| Weep holes for Brick Veneer | segal | Concrete, Stone & Masonry | 11 | 03-24-2012 07:43 PM |
| Buying a house is this crack cause for concern? | whodeydan | General Discussion | 8 | 02-01-2012 02:46 PM |
| More Stone Foundation Repair | PAVenturer | Building & Construction | 11 | 09-18-2011 08:44 AM |
| glass block perimeter channel in brick wall | amakarevic | Building & Construction | 10 | 05-03-2011 10:12 PM |
| Hanging Heavy Sign Post - Into Brick or Mortar? | nikky_hack | Building & Construction | 6 | 11-17-2010 04:04 PM |
