Help With New Block Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-21-2013, 11:28 PM   #1
Rewards Points: 184
Help with new block foundation
Just had the block layed to replace an old foundation under a 14 x 7 addition on house.
1) On 1 side the old floor/sill plate is off level a good bit, about 1.5" over a 7' span. I had the block layed level and now on 1 end the block is against sill and other end of span there is about a 1.5" gap. I was going to fill in this gap with some cement/grout, but I am unsure as to what type to use. Any suggestions?
2) I was originally going to back fill with gravel against new block and put a footer drain in, but now after looking at grading there is no where to run it that will allow a downward slope for drainage. Should I still back fill with gravel if no footer drain is being used? Soil is hard clay with very poor drainage, so I am afraid if gravel is used, pools of water in gravel will sit against block and seep into walls. My thinking is if back filled with old soil/clay, it would prevent large pools of water from forming (that would be against walls) and be better than gravel in this case. Any thoughts on this?
3) I was going to waterproof exterior walls below grade and read a low cost method would be using a thick coat of tar with 6+ mill plastic over top and another layer of tar over plastic, would this be suitable?
Thanks in advance for any help!
stevekem is offline   Reply With Quote
Old 07-22-2013, 09:06 PM   #2
Rewards Points: 184
Anyone have any thoughts on this? Regarding question #1, should I use mortar, hydraulic cement or something else for this?
I am looking for the strongest material that won't break apart very easily when used to fill small gaps.
Old 07-23-2013, 11:10 AM   #3
joed's Avatar
Rewards Points: 11,628
1. nor sure I understand problem. Can you post pictures.
2.Is there a basement? Footer drain and gravel would be my choice. If it can't gravity drain then a sump pump is needed.
3. I would use a real waterproofing method. The plastic will eventually unbond from the tar.
Old 07-23-2013, 08:14 PM   #4
Rewards Points: 4,454
meadows hydralastic 836 & drainage/waffle board ( miradrain ),,, ferguson carries drainage board as do many other const supply houses
ps - its not ' tar ' but a mixture of asphalt cement & water,,, in order to apply tar, you'd have to heat it to 200f & above
Old 07-24-2013, 10:34 AM   #5
Rewards Points: 156
If there's no way to drain to daylight, is it possible to direct the water to a dry well or something?
strategery is offline   Reply With Quote
Old 07-26-2013, 02:06 PM   #6
the most important item is positive drainage ( AWAY from the wall ),,, backfilling w/heavy clay content material is sketchy at best due to the inability to properly compact the fill against a lo-lateral strength block wall as you're denied the use of mechanical plate compactors.
the ' something ' - we often bury a pvc sump ( proper depth ) & install a zoeller m-53 pump,,, we also use a pvc pipe riser to make pump replacement easy ( no digging up the sump )
Lintel block requirement in CMU crawl space foundation Gunn317 Concrete, Stone & Masonry 12 03-20-2013 08:03 PM
Concrete Foundation vs Cinder Block foundation comalley Building & Construction 21 03-13-2013 09:55 PM
8" block foundation lean powderhogg01 Concrete, Stone & Masonry 2 08-06-2012 10:59 AM
repairing parging on block foundation bubbler Concrete, Stone & Masonry 3 03-08-2012 06:09 AM
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 04:57 PM
