Help...messed Up Concrete On Bathroom Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-29-2013, 08:45 PM   #1
Help...messed up concrete on bathroom floor
I need some advice on what my next best option is to fixing the problem I created. An explanation on what I did. First, I put down 1/4" cork, then stapled down radiant heat mat, and then poured self leveling concrete over it. The problem I created was that I saw a few spots were the radiant heat mat was showing through the newly poured concrete and I added more of it to this area. Well, now I have a "bump" in the middle of the bathroom floor--maybe a 1/4" higher than the other parts of the bathroom. I can think of 2 options:
1. Add more self leveling concrete to the lower areas and I've already painted/marked these areas...you should see it the picture.
2. Try and grind down the bump
What should I do? What would work better? If someone thinks grinding it down any recommendations on a "grinder".
***Oh yeah, one more problem I have to put tile on top of this concrete floor. So now I'm concerned with how high this floor will turn out. I do plan on using real thick carpet joining the tile...but I don't want a significant step upwards.
Thoughts???
basementNewbie is offline   Reply With Quote
Old 10-29-2013, 09:59 PM   #2
DIY staff
Rewards Points: 7,174
I see only one sane choice---more self leveling compound---and this time be careful-----
Grinding using a diamond cup grinder would make quick
work of the soft self leveling compound----but one slip and you ruin the heating coil---way to risky for my taste-----
I suggest a wood or marble transition at the door---a raw tile edge is easy to damage--the transition strip will disguise any height difference.
Old 10-30-2013, 07:04 AM   #3
Rewards Points: 4,534
either what mike advis'd OR build-up w/tile thin set,,, self-leveling compound is tricky stuff despite the directions on the pkg we usually use squeegee + magic trowels
Old 10-30-2013, 07:17 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
Where can I get some of those 'magic trowels'?
ddawg16 is online now   Reply With Quote
Old 10-30-2013, 07:29 AM   #5
guessing any wallboard supply house / distributor,,, far's i know, that's where they were 1st used,,, some sher-wms stores carry them,,, we get 'em from our eliteCrete dec conc supplier,,, we use 18" & 24" depending on the job mtl
Old 10-30-2013, 07:47 AM   #6
DIY staff
Got a link to a magic trowel?
Old 10-30-2013, 08:19 AM   #7
ist 1 google found - http://www.amazon.com/s/?ie=UTF8&key...l_3r9oamfhkq_e
The Following User Says Thank You to stadry For This Useful Post:
oh'mike (10-30-2013)
Old 10-30-2013, 09:49 AM   #8
thanks...I'll go with the SLC.
Old 10-30-2013, 11:25 AM   #9
Rewards Points: 660
Doesn't self level cement "sand" down easier than regular cement? I would get a rasp and try and shave the hump down, CAREFUL to not nick the wire. That is what I did with my deck build mortar.
I would try this first before i spent more $$$ on SLC.
B
Beepster is offline   Reply With Quote
Tags
grinder , self leveling compound , self leveling compund
Nasty Septic gas smell from concrete floor Muggle Plumbing 2 02-20-2013 10:34 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
