Help Me Prepare This Concrete For Patching... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 01-06-2017, 02:33 PM   #1
Rewards Points: 215
Help me prepare this concrete for patching...
I am needing to patch this dip in the concrete to prepare it for vinyl tile. Do I need to remove this floor paint prior to patching? What is the best way to do so if necessary?
bassadict69 is offline   Reply With Quote
Old 01-06-2017, 02:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Re: Help me prepare this concrete for patching...
Grind off the paint and prep the surface.
Plug the hole. Poor leveling compound and allow for full cure.
Bondo likes this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
bassadict69 (01-06-2017)
Old 01-07-2017, 03:28 PM   #3
Rewards Points: 215
Stuff wasn't as easy to work with as I had hoped. Was really hard to get it very smooth.
Old 01-09-2017, 11:46 AM   #4
Rewards Points: 4,440
if you used true self-leveling mtl, you found out it isn't,,, it still needs 'hands-on' work,,, we would've used fast setting cement instead
Old 01-11-2017, 07:47 PM   #5
Rewards Points: 215
I used some quickrete vinyl patching compound... had to sand it to get it even close to smooth.
Framing for Room half over old Concrete porch posulli Building & Construction 2 11-17-2016 03:43 PM
New Concrete Over Old Concrete Pier succeed Concrete, Stone & Masonry 1 09-05-2016 04:05 PM
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 05:10 AM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
