Help With Leaking Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-06-2012, 04:13 PM   #1
Rewards Points: 14
help with leaking chimney
We have had water leaking around our fireplace since we built our house 4 years ago. I have a 2 story house, with a full mason chimney. one leak is on the ceiling above the fireplace on our first floor, the other is below the fireplace in the basement. The leak seams worse on driving rains. The leak in the basement has water rolling down the back wall and under where the frame meets the foundation, which is above grade. builder has had roofer, siders, and the mason out several times. We have replaced the cap once, ref lashed 3 times, they have removed the bottom 4 feet of the fireplace 2 times but I am still getting water. Our builder and mason have gone out of business and I am looking for advise on who best to hire to track down the leak?
dartman92 is offline   Reply With Quote
Old 03-06-2012, 04:21 PM   #2
Civil Engineer
Rewards Points: 4,568
When my brick chimney leaked, I had a mason come out. He installed a concrete cap on the top of the chimney, pretty ugly, but it stopped the leak for five years. Next time it leaked, I had a local mason install a stainless steel cap over the chimney, plus he fixed the deteriorated flashing by using bituminous caulk. Probably should have sprung for all new lead flashing, but it is expensive because of the work to remove bricks etc. My guess is you have a flashing problem, obviously the people who installed would have been the most knowlegeable about what problem they created, but since they are out of business, you probably need a new mason, maybe a competent one this time. Sorry for your troubles, but it sounds like flashing is a likely candidate, maybe the cap.
Old 03-06-2012, 04:30 PM   #3
Rewards Points: 14
Additional info and photos
I have attached some photo's of the water coming in from the basement and a picture of the outside of the chimney.
Old 03-06-2012, 05:11 PM   #4
Chicago, IL
Michael Thomas's Avatar
Hard to say anything without pictures of the entire chimney at the exterior.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Tags
chimney leak , leak detection , mason
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Chimney or roof leaking? hforbes Roofing/Siding 8 03-11-2011 04:44 PM
Chimney leaking AgentW Building & Construction 43 12-23-2010 11:20 PM
chimney leaking into attic kelley4180 Roofing/Siding 10 02-12-2010 10:55 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
