Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-18-2012, 12:27 PM   #1
Help identifying retaining wall blocks
Hello. I have a decent sized run of retaining wall blocks (275+caps), which were poorly installed at our new house. I am wanting to re-do them correctly, but am not sure about what make they are and I will need to buy more to finish the project correctly.
My best guess is, an Allan Block, but they are the shape of the allan block jumbo, and the size of the allan block jumbo junior (7 5/8"D x 7 5/8"W x 6"H)
If anyone has any ideas I appreciate it.
Thanks!
Drizzt is offline   Reply With Quote
Old 04-18-2012, 12:35 PM   #2
Tool Geek
PaliBob's Avatar
Hi Driz, There must be thousands of different different styles of block around the world. Your most sure bet would be to take it to your closest block supplier.
& Stay Safe
.....Bob Lavery
Old 04-18-2012, 12:45 PM   #3
Ok thanks. Unfortunatly they are 11 years old, so hopefully they don't change often, or they are a block supplier historian.
Old 04-18-2012, 01:13 PM   #4
concretemasonry's Avatar
Drizzt -
They look like the older (developed in 1988) Allan Block units because of the raise shear lip on the front. The exact units may not be available since they have been improved to agree with 3 other internationally licensed products developed in the U.S. that carry DOT and other code approvals.
Many of the common low volume units made by local producers are "knock-offs" with minor dimension differences and not qualify for most standard municipal or state work, but could be adequate for small residential applications.
Dick
concretemasonry is offline   Reply With Quote
Old 04-18-2012, 01:21 PM   #5
That makes sense, as I've had a tough time identifying these blocks. I did leave a message with AB too, so they might be able to confirm (there is an AB processing plant near my city). But if that's the case, I may run into some problems finding supplies to finish the project off.
Old 04-19-2012, 01:43 PM   #6
Those are Allen Block Juniors.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 04-19-2012, 01:59 PM   #7
Thanks. I contacted AB and they confirmed that too. It looks like they have changed their forms though, so I am awaiting a response as to if you can mix old + new juniors together.
AB Junior
AB Junior Angle
http://www.allanblock.com/ca/Install...uild.aspx?ta=1
Thanks.
Tags
retaining wall
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
Cheapest Retaining wall diy4life Landscaping & Lawn Care 15 03-21-2012 11:18 AM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Retaining wall Hurriken Landscaping & Lawn Care 7 09-22-2009 12:26 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 02:22 PM
