Help With Groundwater - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-13-2013, 10:52 AM   #1
Help with groundwater
Hi,
New to forum, and hoping I can get some help.
My MIL's house was built in 1800's. Over time the dirt floor was covered with a thin layer ( 1-2 inchs ) of concrete. She wants to put a GE Geospring Hot Water Tank system in.
I have to dig down 18 inches and pour a concrete pad for the plumber becasue of the low height in the basement. That is 90% complete .
The problem is, I keep getting ground water seeping in and filling up the hole ( 5' x 5' ). The water is seeping in from 3 sides of the hole. I will try to take some pics tonight and post them.
Trying to figure out if there is a way to stop the water from coming in on the sides long enough to pour concrete walls and then pour the bottom pad?
Or should I dig a seperate hole to make a sump pit and connect it to the original hole and set up a sump pump and line to discharge the water??
NHMike is offline   Reply With Quote
Old 05-14-2013, 07:11 AM   #2
Rewards Points: 4,454
you can't stop it so digging a sump pit & installing a pump will work,,,uncertain why you need a 18" thick pad for the plumber but that's another story,,, maybe he's a tall plumber & needs some headroom ?
whatever you do, the sump pump's gotta stay,,, you're casting a boat's hull & it will float,,, sounds as if you're facing a high water table issue.
Old 05-14-2013, 08:43 AM   #3
That's what I thought. I don't need an 18" thick pad, I have to dig down 18" becasue the Geospring Hot Water heater is tall. The basement is only 5' in height.
I guess I will have to dig a channel and pit off the left corner, and make it deeper than the pad area so the water will drain down to it.
Water in basement in older home plume Concrete, Stone & Masonry 10 05-06-2013 01:51 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Stupid question about floor drains. Oliver's Army General DIY Discussions 12 07-08-2009 10:53 PM
Major groundwater problem please help!!! rainer321 Landscaping & Lawn Care 1 04-24-2007 03:25 PM
Groundwater Movement MSC Landscaping & Lawn Care 2 08-10-2005 11:28 AM
