Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-15-2012, 11:44 PM   #1
Help! - Fix stone on front of house above egress windows
Yesterday I cut out a hole in my concrete foundation and installed a window in the basement. All went well, but now I need to replace about 9" of stone on the front of the house right above the new window as right now I have the 2x8 header exposed.
I have never done any mason work and I'm a bit confused. The stone on the house now is simply up against the house with about 1" gap in between the stone and osb on the house.. no moisture barrier no nothing!.. Just some metal ties that go into the mortar every foot or so.. is this normal? Either way, can I use mortar mix and extra stones and fill in the gap? do I need a piece of angle iron above the egress window to rest the stones on? Would that work, and is the mortar waterproof then?
retto216 is offline   Reply With Quote
Stone Veneere on the Front of the House. hamscam Remodeling 4 09-22-2012 09:46 PM
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-17-2011 12:59 AM
Insulating house with stone walls mlupa Building & Construction 3 11-26-2008 10:19 PM
Building A Stone House In An Semi-Earthquake Enviroment Silverbackman Building & Construction 12 03-28-2006 03:43 AM
