Help Filling Chimney Hole In Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-17-2013, 08:55 PM   #1
Help filling chimney hole in foundation
Need some advice on filling a hole in my poured foundation. We are switching to gas and removed the oil chimney.
The hole is 10" diameter and approx 8" deep. Vertical wall.
My questions are:
What type of concrete should I buy? I was leaning towards the quickrete stuff but would hydraulic be better?
Do I need to apply a bonding agent to the existing wall?
Should I fill the hole with a couple of bricks and then fill it up with the concrete?
I already attached and sealed the outside with a piece of plywood (until I get the concrete in) can I leave it there and fill the hole. Then remove it after?
Do I need to put oil or Vaseline or something on it so the concrete doesn't stick to it?
Thanks in advance!
BTW love this forum...long time lurker.
Squints is offline   Reply With Quote
Old 06-17-2013, 08:57 PM   #2
Here is a pic of my hole. Lol
Old 06-17-2013, 08:58 PM   #3
Old 06-17-2013, 11:59 PM   #4
Rewards Points: 13,270
Leave the plywood in place and use hydrolic cement. Once it sets up remove the plywood and do the outside.
Need of reinforcement of foundation wall due to HVAC ductwork hole? whoopus Building & Construction 1 07-18-2012 12:50 PM
Chimney dimensions to use for foundation dimension jperry2109 Building & Construction 4 04-07-2012 09:55 AM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 09:16 AM
Small Foundation Hole? jage Building & Construction 1 11-06-2009 03:24 PM
Filling a Chipmunk Burrow Hole handy man88 Landscaping & Lawn Care 1 09-08-2008 03:26 PM
