Hardie Backer? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-13-2012, 01:01 PM   #1
Rewards Points: 722
Hardie Backer?
I am wanting to start building the framework for an outdoor kitchen. My plan is to build a frame out of treated lumber then cover that in Hardie Backer Cement board and eventually cover with a thin stone. My neighbor is a brick mason and said he'd lay the stone for me, but not sure how soon I'll get around to that, may actually be next spring. So my question is, if I were to frame it this fall, but wait until spring to install the stone will the cement board still hold up? What if I put the scratch coat on it?
My neigbor thought it'd be ok, but figure I'd ask here as well. The hardie backer would also be used on the counter top, until I could get a pour in place concrete countertop poured, but I might be able to get to that before winter.
Thanks!
Master Brian is offline   Reply With Quote
Old 08-13-2012, 01:05 PM   #2
Rewards Points: 13,256
Personly I would hold off and build it when I had all my ducks in a row to finish it.
I also would do some more research on what the maufactures of that stone your going to use say about what to use as a substrate.
Master Brian (08-13-2012)
Old 08-13-2012, 04:23 PM   #3
outdoor kitchen
i would wait and do everything at once
you could frame it in with plywood and attach wire mesh to it
apply a plaster coat of mortar to the mesh
then apply the stone
for chimney repair in Grand Rapids,Michigan go to www.boonstramasonry.com
jamaicajoe is offline   Reply With Quote
Hardie backer board textured with thin set wildwort Tiling, ceramics, marble 14 11-21-2011 11:01 AM
hardie backer and subfloor question nascarnut19 Tiling, ceramics, marble 11 05-29-2011 09:15 AM
remove and reinstall hardie backer montpsycho Carpentry 3 01-17-2011 12:28 AM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 06:40 PM
Hardie Backer to drywall transition jnbrown Drywall & Plaster 1 12-27-2008 03:12 PM
