Hand Mixing 6 Bag Concrete For Stamped Slab. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-11-2012, 01:48 PM   #1
Hand mixing 6 bag concrete for stamped slab.
How many shovels of 60/40 pea gravel and sand to each shovel of portland cement?
Jerry Collell is offline   Reply With Quote
Old 06-13-2012, 06:43 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
How big of a slab? On a stamped slab, I'd recommend getting a truck. Mixing it yourself it could get away from you pretty easily.
Of course, anything over, say, 3/4 of a yard, you'll be money ahead getting a truck.
Mort is offline   Reply With Quote
Old 06-13-2012, 06:45 PM   #3
I thought "dwarf" was the politically correct word. . .?
Old 06-13-2012, 07:02 PM   #4
Rewards Points: 13,250
http://www.concretenetwork.com/concr...calculator.htm
Do you even have the stamps to do this?
Old 06-13-2012, 09:46 PM   #5
Mort's Avatar
Rewards Points: 690
I'm sure it is, however, I can't think of a less politically correct person than me.
Old 06-14-2012, 02:11 AM   #6
Too Short? Cut it Again!
Stamping concrete nicely is an artisan thing. As Joe asks, "do you have a sufficient number of stamps on hand?"
And beyond that, do you know the slump you have to achieve and just when to stamp? Are you mixing a colorant? Do you have adequate help lined up to move things along because you will have a relatively small window to make this happen.
I am not saying a diyer cannot stamp concrete. I have never seen something like a large patio slab turn out looking like much though and certainly remember a few having to come out, be reformed and repoured.
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
