Hairline Cement Cracks In Ceiling Of Highrise Condo - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-13-2013, 10:11 AM   #1
hairline cement cracks in ceiling of highrise condo
Looking to purchase a condo on the twelfth floor of a highrise, but there are many hairline cracks in the cement ceiling that run every which way. Should I be concerned of any danger?
Yodgie is offline   Reply With Quote
Old 01-13-2013, 11:52 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,.... Just where in the World is it,....
'round here, I wouldn't worry in the least,...
In LA, Ya I might be worried....
The Following User Says Thank You to Bondo For This Useful Post:
Yodgie (01-13-2013)
Old 01-13-2013, 01:05 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
There are 2 kinds of concrete, concrete that is cracked and concrete that is going to crack. (at least that is what they tell me)
Hairline cracks are ok.....it's when you see the edges of the crack starting to crumble....it's an indication that you have movement which means there is an issue.
Hopefully Dan H or one of our other experts will chime in ....
On a side note.....I've done two slabs now....1st one was my garage...20x25...contractor did all the work....but I watched in detail....it was all done right.....and I have hairline cracks.
Second slab is part of my 2-story addition....I hired a guy to do most of the work....but I went through all the details on this one myself....the rebar is right...good solid base (we dug down only 6" and left the rest packed dirt undisturbed)...sand base....plastic....3500 PSI concrete....at least 4" thick....kept it coverd for at least 2 weeks and kept it moist......and I have hairline cracks.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Yodgie (01-13-2013)
Old 01-13-2013, 04:37 PM   #4
Thanks Bondo, the condo is in Long Beach, California, and the building is nine years old.
Old 01-13-2013, 05:57 PM   #5
Rewards Points: 3,624
There's a list of things as long as your arm that could cause those cracks,and no one is sure just which one of them caused it,so just go for it.
Canarywood1 is online now   Reply With Quote
Old 01-13-2013, 10:18 PM   #6
JOATMON
ddawg16's Avatar
I bet I know exactly where that is....your most likely in one of two spots....one that has a great view of the beach and ocean....the other, a great view of the Long Beach Grand Prix....
Your going to be fine....LB does a good job of making sure everything is safe.
Yodgie (01-13-2013)
Old 01-13-2013, 10:32 PM   #7
You are absolutely right. The condo is in the Aqua Towers with a view of the city. BTW, I just spent a delightful hour going through your blog about the two story addition to your house. Fantastic. Loved every minute of it and will check back to see how you complete it. I was thinking how awful it would have been if I had built it, since there is no way in h--- that I can nail two boards together straight. All the best to ya and thanks for taking the time to write to me.
Old 01-17-2013, 08:41 AM   #8
Rewards Points: 4,642
w/o pics, only guessing,,, perhaps flex cracks due to heavy or early loading on the floor above - rebar not correctly sized OR placed correctly - more wtr than spec'd conc mix - incorrect mix design - incorrect pump mix any indication of movement ?
The Following User Says Thank You to stadry For This Useful Post:
Yodgie (01-17-2013)
Is 100% silicone fine for sealing cracks in cement patios? amodoko Concrete, Stone & Masonry 4 11-25-2012 06:51 AM
New concrete patio has hairline cracks throughout-what are my options? Tina1112 Concrete, Stone & Masonry 4 10-02-2012 09:44 PM
Waterproof walls & Ceiling in Condo tstorzuk Building & Construction 2 12-27-2010 10:12 AM
Drywall Cracks in High-Rise Condo ghanson Drywall & Plaster 1 12-29-2009 02:02 PM
Condo Drop Ceiling transformed into a Lighted Trey Ceiling Sir MixAlot Project Showcase 14 06-28-2008 07:58 PM
