Ground Prep For Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-26-2012, 12:01 AM   #1
Ground prep for concrete
About ready to lay our concrete pad (8x16) and had the stump grinder guy over today to take out to massive stumps. He said I would be fine to leave the wood chips (lots of them) since I'm bringing in about 4" of fill dirt before laying the pad.
You guys think I'm okay not cleaning out the wood chips?
dclay79 is offline   Reply With Quote
Old 07-26-2012, 02:09 AM   #2
Rewards Points: 2,210
Clean them out, they rot and leave gaps.
Also not dirt for fill but gravel.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
oh'mike (07-26-2012)
Old 07-26-2012, 06:46 AM   #3
Rewards Points: 1,294
The stump grinding guy is the last guy I would depend on for advice on prepping the ground for concrete. Idealy you should have someone come in and remove the rest of the stump that he left just below the surface of the ground and have it filled properly. Once that starts to rot all of the support under the slab will be gone.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 07-26-2012, 09:16 AM   #4
Concrete & Masonry
Rewards Points: 530
Pull out all the loose wood chips and replace with granular (gravel) material, compacting every few inches as you fill.
Technically, the stump "could" rot out and create a void, but in reality it takes decades, often even longer, for it to become a significant issue.......
jomama45 is offline   Reply With Quote
Old 07-26-2012, 10:32 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I had a stump ground because it was in the way of my stair landing for my deck (5' x 4' concrete pad) Just the "spongy" feeling you get from walking over the wood ships was enough to scream "get them outta there" for me. I would certainly not leave them. I still expect the pad to move in a few years just because the stump grinder could only go about 12 or 16" underground.
CoconutPete is offline   Reply With Quote
Old 07-26-2012, 03:11 PM   #6
You know I figured he didn't know what he was talking about.
I'll get out most of it, and probably move the remainder of the contaminated dirt to an area where the concrete won't be.
I was wondering about the stump rotting, and I REALLY don't want to deal with that. Good news is the stump goes underground about 18 inches away from where the concrete ends. It was a beast because it took a 90* angle and ran along the ground for 3 feet or so before. I've tried to get as many roots as possible, but I don't think I'll ever get all of them.
As for the gravel - I've spoken to 4 different highly recommended concrete contractors out here and they ALL say gravel isn't needed, and just put it straight on the dirt. I thought this was crazy, but after the 4th I started to believe them. We're planning on filling the non concrete area with gravel as well, so we might as well get a larger load of gravel instead of gravel and dirt. It'll be a better base and its cheaper. Gravel it is
Old 07-26-2012, 05:46 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 624
Ayuh,.... It'll be Many Decades for it to rot away,... They're still diggin' stumps outa Ireland that are 1000s of years old....
Bondo is online now   Reply With Quote
Old 07-27-2012, 11:20 PM   #8
Well I got most of the chips out. Frick that was a pain. Now on to the soil leveling and then in comes the gravel. I've been planning on renting the plate compactor from Home Depot to help out, but I read these aren't okay for soil compacting. Is that true? the top inch or two in the entire area is fairly loose from taking out the old concrete.
Also I did a quick measure, it looks like the deep end of the plot is about 10" inches under grade as it sits. The shallow end by eyeball is closer to 7". That's going to be a lot of gravel. Oh joy.
Old 07-29-2012, 03:46 PM   #9
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
I don't see why you couldn't compact it with one of those, beats the hell out of doing it by hand. And yes that's a lot of gravel, but its cheaper than making your slab that thick.
Mort is online now   Reply With Quote
Old 07-29-2012, 07:20 PM   #10
Rewards Points: 162
Compacting with a plate compactor is pretty typical - I used a plate compactor when I placed the 6" of stone under my patio and sidewalk.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 08-04-2012, 09:11 PM   #11
Rewards Points: 3,418
The general rule is a plate compactor for sandy soil,and a jumping jack for clay.
Canarywood1 is online now   Reply With Quote
ground cover prep Startingover Landscaping & Lawn Care 2 06-24-2012 10:02 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
