Grinding Or Cutting A Small Notch In A Quartz Counter - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-05-2013, 12:10 PM   #1
Rewards Points: 18
Grinding or cutting a small notch in a quartz counter
We had our quartz countertops installed a few days ago, but unfortunately, the cutout for the cooktop is just a tad bit too small for our cooktop to drop in. There are a couple screws on either side of the cooktop that are not fitting. If I want to try and notch out a little bit (about 1/8" deep by 1/8" wide) of the counter to fit the screws, what kind of tool should I use? Or is this even recommended for a novice DIYer? The part I want to grind/cut will not be seen so I don't care if it's rough, I just don't want to crack the counter.
pdp76 is offline   Reply With Quote
Old 04-05-2013, 12:56 PM   #2
Rewards Points: 4,800
dremel tool will work just fine,,, and added bonus is no one rents them so YOU get an early ( or late ) Christmas present we NEVER have enough or the ' right ' tools IF your bride's too cheap to loose some $$$ your way, a hacksaw'll work but more tools are better
Old 04-05-2013, 01:01 PM   #3
Rewards Points: 18
I already have a Dremel, so no new toy for me But maybe I can get a new attachment! What type of grinding material/attachment would you recommend?
Old 04-05-2013, 01:12 PM   #4
tell her whatever you need - my basic point is ' BUY TOOLS ! ',,, i don't have 1 but, as i recall, the dremel blades're about 1 1/4" in diam & probably an abrasive mtl,,, our saw's 14" w/diamond blade
Old 04-05-2013, 01:33 PM   #5
Rewards Points: 3,828
Why are you doing this anyway,it's the installers job.
Canarywood1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Canarywood1 For This Useful Post:
747 (04-06-2013), joecaption (04-05-2013)
Old 04-05-2013, 01:40 PM   #6
Rewards Points: 744
Because, he probably didn't have the cooktop available, when the granite installers were over.
The dremel may work for those small cuts. Get the diamond wheel for it.
Seattle2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Seattle2k For This Useful Post:
pdp76 (04-06-2013)
Old 04-05-2013, 03:45 PM   #7
Rewards Points: 18
Exactly, the cooktop wasn't delivered yet... though I did have the specifications and showed it to them... but they still cut the hole about 1/8" too narrow. I even pointed it out but they assured me it would be ok... douches...
Anyway, yeah, I'll look for a diamond wheel, that's the answer I was looking for, thanks a bunch!
Old 04-05-2013, 05:02 PM   #8
I'd have called them back.
joecaption (04-06-2013), oh'mike (04-05-2013)
Old 04-05-2013, 05:50 PM   #9
DIY staff
Rewards Points: 7,174
Keep a brick or chunk of old tile handy to clean the diamond bit---the quartz top gums up the diamond bits---when it stops cutting---clear it by cutting the brick----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
pdp76 (04-06-2013)
Old 04-06-2013, 05:32 AM   #10
what a GREAT thread,,, always wanted a dremel but diamond blades weren't avail according to our apron/vest guys,,, since we only engrave conc, no way i'd have another tool lying around not being used,,, evidently NOW diamond discs ARE avail so i'll buy 1 good tip on cleaning the glaze off the diamonds, mike,,, we often just turned off the wtr for a quik second to deglaze dia blades & core bits
thanks again !!!!!!!!!!!!!
The Following User Says Thank You to stadry For This Useful Post:
oh'mike (04-06-2013)
Old 04-06-2013, 10:37 PM   #11
Msradell's Avatar
Rewards Points: 348
If they cut the whole smaller than was specified, then they should come back and repair it, since the cooktop doesn't fit! It's their responsibility, don't take the risk yourself.
Msradell is online now   Reply With Quote
Grinding small stumps with hand grinder nikeman Landscaping & Lawn Care 15 06-16-2017 04:38 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Cutting small trees with sawzall vs chainsaw Red Squirrel Tools 32 08-25-2011 06:23 PM
Cutting off 3" of laminate counter top in place 4just1don Building & Construction 3 09-27-2008 09:33 PM
Is a small notch in a wind brace ok? twilightcall Carpentry 2 06-27-2008 11:06 PM
