-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Grinding or cutting a small notch in a quartz counter (http://www.diychatroom.com/f105/grinding-cutting-small-notch-quartz-counter-176367/)
pdp76 04-05-2013 12:10 PM
We had our quartz countertops installed a few days ago, but unfortunately, the cutout for the cooktop is just a tad bit too small for our cooktop to drop in. There are a couple screws on either side of the cooktop that are not fitting. If I want to try and notch out a little bit (about 1/8" deep by 1/8" wide) of the counter to fit the screws, what kind of tool should I use? Or is this even recommended for a novice DIYer? The part I want to grind/cut will not be seen so I don't care if it's rough, I just don't want to crack the counter.
stadry 04-05-2013 12:56 PM
dremel tool will work just fine,,, and added bonus is no one rents them so YOU get an early ( or late ) Christmas present :thumbsup: we NEVER have enough or the ' right ' tools :laughing: IF your bride's too cheap to loose some $$$ your way, a hacksaw'll work but more tools are better :thumbup:
pdp76 04-05-2013 01:01 PM
I already have a Dremel, so no new toy for me :( But maybe I can get a new attachment! What type of grinding material/attachment would you recommend?
stadry 04-05-2013 01:12 PM
tell her whatever you need - my basic point is ' BUY TOOLS ! ',,, i don't have 1 but, as i recall, the dremel blades're about 1 1/4" in diam & probably an abrasive mtl,,, our saw's 14" w/diamond blade :thumbsup:
Canarywood1 04-05-2013 01:33 PM
Why are you doing this anyway,it's the installers job.
Seattle2k 04-05-2013 01:40 PM
Because, he probably didn't have the cooktop available, when the granite installers were over.
The dremel may work for those small cuts. Get the diamond wheel for it.
pdp76 04-05-2013 03:45 PM
Exactly, the cooktop wasn't delivered yet... though I did have the specifications and showed it to them... but they still cut the hole about 1/8" too narrow. I even pointed it out but they assured me it would be ok... douches...
Anyway, yeah, I'll look for a diamond wheel, that's the answer I was looking for, thanks a bunch!
Canarywood1 04-05-2013 05:02 PM
I'd have called them back.
oh'mike 04-05-2013 05:50 PM
Keep a brick or chunk of old tile handy to clean the diamond bit---the quartz top gums up the diamond bits---when it stops cutting---clear it by cutting the brick----
stadry 04-06-2013 05:32 AM
what a GREAT thread,,, always wanted a dremel but diamond blades weren't avail according to our apron/vest guys,,, since we only engrave conc, no way i'd have another tool lying around not being used,,, evidently NOW diamond discs ARE avail so i'll buy 1 :thumbup: good tip on cleaning the glaze off the diamonds, mike,,, we often just turned off the wtr for a quik second to deglaze dia blades & core bits :yes:
thanks again !!!!!!!!!!!!!
Msradell 04-06-2013 10:37 PM
If they cut the whole smaller than was specified, then they should come back and repair it, since the cooktop doesn't fit! It's their responsibility, don't take the risk yourself.
