Grinding Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By de-nagorg
  • 1 Post By clarenceboddick
Old 12-25-2016, 04:19 PM   #1
Grinding concrete
I'm getting ready to do a small brick paver project. There's a pole support for our carport in the project area. The concrete support for the pole sits a little higher than the surrounding slab. I'd like to grind the concrete down flush to the slab/finished pavers. I'd also like to square it off hopefully with a skill saw.
What's the best way to do this? I'd like to use a grinder if possible.
Ashearer is offline   Reply With Quote
Old 12-25-2016, 04:26 PM   #2
Rewards Points: 2,766
Re: Grinding concrete
Angle grinder with a carborundum blade.
Careful not to nick the pole.
Same kind of blade in the circular saw.
Wear dust mask, or keep a trickle of water flowing.
Patience, no hurrying, or force to the blades, they break throwing shards violently.
ED
Mrbuilder likes this.
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Ashearer (12-25-2016)
Old 12-25-2016, 08:25 PM   #3
jlhaslip's Avatar
Rewards Points: 2,862
Carborundum Cup Stone on the grinder
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-26-2016, 06:34 AM   #4
Rewards Points: 944
I'd use a diamond cup grinder. They are easy for beginners to use. Be advised that you will be making a lot of dust.
Bud9051 likes this.
clarenceboddick is offline   Reply With Quote
Old 12-26-2016, 07:56 AM   #5
Thanks for the replies. I'll be heading to Home Depot shortly to pick up that blade.
Concrete floor grinding?? nerakj Concrete, Stone & Masonry 9 07-25-2015 04:18 AM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
