Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-24-2012, 06:35 PM   #1
Question
Grind down concrete floor to get more ceiling height?
We plan on converting an attached garage into two bedrooms and a mixed-used area. It's about 700 sqft total. The issue is with ceiling height. From concrete floor to bottom of existing ceiling (5/8" plaster) is 7ft 5in. Code requires 7ft 4in for the finished space. That leaves me only 1" to seal and insulate the concrete and install a floor. I'd like a little more space, preferably so I can put another layer of ceiling drywall up for sound insulation.
So I can think of two options, both I'd have to contract out... just looking for some opinions:
1. Remove & Re-pour. I'd go about 8" deeper, add in thick insulation and a vapor barrier. Maybe even radiant. But that's going to set me back about $7000 not including the heat. I'm reasonably sure there are no structural issues and the concrete foundation footings are over 36" deep. House was built in the late 1940's.
2. Grind the floor down 1". How cost effective would this be, assuming I can find someone to do it? The floor is 1.5" thicker than the rest of the basement, so I'm pretty sure it could handle being 1" thinner. It's in very good shape now with no cracks but is dirty with oil and grease. Grinding would help get rid of the smell too. I've seen big buildings get it done with next to no dust, but I don't know if that's done on a residential scale.
Any thoughts? I hate to spend thousands of dollars to get an inch!! How would you guys approach this?
Thanks!
JimR1998 is offline   Reply With Quote
Old 05-24-2012, 07:40 PM   #2
Raise the ceiling, not lower the floor.
Ravenworks (05-24-2012)
Old 05-24-2012, 08:05 PM   #3
Super Moderator
Is the garage single story? I vaulting the ceiling an option?
Could you remove the floor and dig--then add conventional framing?
A little more info is needed---pictures always help,too.
oh'mike is online now   Reply With Quote
Old 05-24-2012, 09:26 PM   #4
Sorry for leaving out a critical detail.
The house is a ranch with a garage / walkout basement on the lowest level. We can't go up, since the existing main house is on top. As part of the basement refinish, we're converting the garage into bedrooms and extra living space.
If we remove the floor and dig... not sure I understand about conventional framing? Where would that be needed? The top of the footers are about 6" under the concrete. Not sure how wide they are inside, so we'd have to take that into account if we re-poured. Would it be permissible to have a small ledge or bump out near the floor if we poured lower than the footer top?
Old 05-24-2012, 10:41 PM   #5
Super Moderator
I meant wood framing--sorry,bad idea--
Plenty of folks here with more concrete knowledge than me--let's wait for one to read this--Mike--
How to fix concrete CEILING?? Tim_ Concrete, Stone & Masonry 1 05-24-2012 04:37 PM
Concrete ceiling condensation Snowdog Insulation 4 12-10-2011 10:43 AM
standard ceiling height iggy525 Building & Construction 10 12-31-2008 12:31 AM
Suspended Ceiling Min Height? mfleming Building & Construction 6 10-17-2008 09:42 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
