On Grade Footings. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-04-2013, 09:37 PM   #1
Rewards Points: 222
on grade footings.
i have these rooms in my basement that i want to excavate and use for something. as it turns out, the foundation of the outside walls and that middle wall, does not go "into" the ground. the footing was dug just below grade and the blocks are just about above grade.
so, i understand i cannot dig right up to the footings. but how close can i get ? the ground is dirt and pretty solid. the middle wall, it is not load bearing, so i plan to bust that out.
i was planning to make the closest room a full bathroom. and the further room storage. and i still can, but the rooms would be much smaller.
i'm fishing for ideas here.
1st room 5.5'x about 11'. 2nd room 6.5'x11'.
Fix'n it is offline   Reply With Quote
Old 03-04-2013, 11:10 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
That situation could turn ugly quickly, for your safety and peace of mind I would recommend having an engineer check that out and give you advice, digging too close to your existing footing could be dangerous. We can't know all there is to know to give you a safe answer. JMHO
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
GBrackins (03-04-2013), joecaption (03-04-2013)
Old 03-05-2013, 08:49 PM   #3
Rewards Points: 222
yeah, i know. i was thinking i could safely stay 3' back. idk what i am going to do yet. and i am not in a hurry. i was hoping someone had an idea i had not thought of.
Exterior wiring above and below grade for hot tub in Pennsylvania pkcrouse Electrical 0 05-31-2012 11:49 AM
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 01:46 PM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 03:40 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
