Get Rid Of Windows And Close Up The Wall. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-29-2012, 01:38 PM   #1
get rid of windows and close up the wall.
How do I fill up the open spaces in the wall where the window used to be?
klussen is offline   Reply With Quote
Old 06-29-2012, 02:06 PM   #2
Rewards Points: 502
tony.g is offline   Reply With Quote
The Following 3 Users Say Thank You to tony.g For This Useful Post:
CopperClad (06-29-2012), Evstarr (06-29-2012), Fix'n it (07-01-2012)
Old 06-29-2012, 02:35 PM   #3
As per Tony's drawing he is only showing 3 nails/screws. I'm pretty sure code is minimum 5 per connection. Even if code is only 3 in your area I would still add a couple more to be safe. And also remember to caulk any edges with Crisco after the installation of your covering as this gives the best seal from termites and rattle snakes. Just remember to take your time! You're not in a race !
CopperClad is offline   Reply With Quote
Old 06-29-2012, 09:07 PM   #4
Davejss's Avatar
Rewards Points: 776
Due to recent socialist health care regulations you will have to post, in a conspicuous location, the calroie count of the crisco.
Davejss is offline   Reply With Quote
framing two windows very close together ChrisJJ Building & Construction 5 02-09-2011 04:27 PM
Attic windows: how much to close them? Flexicon Roofing/Siding 2 01-01-2011 07:44 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
