Gas Fire Pit On Wood Deck - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-23-2013, 08:23 PM   #1
Gas fire pit on wood deck
I'm looking to put a gas fire pit on my wood deck. The plan is to frame out the walls, cover with duroc, put stone veneer on the outside, cap with 2" sandstone slab, fill the middle with gravel, install a gas fire ring, then top with decorative recycled glass. Does this sound ok? With all of the heat being generated above the actual fire pit I'm thinking the heat transfer will dissipate before it gets to the wood.
Jeff213 is offline   Reply With Quote
Old 09-25-2013, 07:22 AM   #2
Rewards Points: 4,442
gas burns at a fairly low temp so it sounds ok to me but i'd add a layer of mineral wool insulation to be more assured,,, you might ck w/your ins co or local fire dept,,, heat rises but will also transfer thru solids fairly easily
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 04:47 PM
Is Natural Gas Firepit on a Wood or Composite Deck unsafe? Jakobud General DIY Discussions 4 03-29-2012 04:43 PM
Replacing Deck - Can I seal the wood first? mdawson3k General DIY Discussions 4 06-27-2011 11:43 AM
New Trex Deck just installed with wood deck screws instead of composite- HELP PLEASE! JLayman Building & Construction 3 08-07-2009 11:20 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
