Garage Floor Semi Gloss Sealer? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-28-2014, 09:20 PM   #1
Rewards Points: 260
garage floor semi gloss sealer?
Hi you guys. I'm wanting to seal my garage floor with a high gloss or semigloss clear sealer. I don't want to paint it. Do you know of a good product to use? Thanks.
Jesse
jpearson311 is offline   Reply With Quote
Old 04-29-2014, 05:19 AM   #2
Rewards Points: 4,654
sher-wms owns h&c & has products that will probably be acceptable to you,,, they're not something knowledgeable pro's use but they'll work,,, house painters aren't generally knowledgeable about floors/coatings/acceptable mtls so sher-wms sells lots of h&c stuff to painters
irc
stadry is online now   Reply With Quote
Old 04-29-2014, 07:07 AM   #3
Gymschu's Avatar
Rewards Points: 838
Your local concrete plant will have what you need. The stuff is quite toxic so I hope you can ventilate your garage.
Or you can go to Home Depot and get something like this:
Old 04-29-2014, 07:12 AM   #4
Rewards Points: 260
irc
Something like this?
Old 04-30-2014, 06:52 AM   #5
that'll be fine,,, you might want to stir in some shark's grip for better traction,,, stir OFTEN to keep the grip in suspension,,, & ALWAYS 'work' to a wet edge - if the sealer dries while you're sealing, you'll have roller tracks -1 reason we use 18" rollers
Old 04-30-2014, 07:01 AM   #6
Gymschu's Avatar
Rewards Points: 838
Advice from another thread about the quality of Euclid products:
http://www.euclidchemical.com/produc...ing/everclear/
Old 04-30-2014, 10:58 AM   #7
Rewards Points: 260
Do I have to apply multiple coats?
Jesse
Old 04-30-2014, 11:26 AM   #8
we use 2 thinn'd coats of ' CSS ' our sealer of choice
irc
The Following User Says Thank You to stadry For This Useful Post:
jpearson311 (04-30-2014)
Old 08-01-2014, 09:32 PM   #9
You want to go with an epoxy or an aliphatic polyurethane. Which one you go with depends on your need and budget. Avoid acrylic coatings. Acrylic coatings will soften when they come into contact with oil and gas.
ConcreteChic is offline   Reply With Quote
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
Uneven gloss after spraying garage. Austin83 Painting 6 07-21-2011 07:29 AM
