Garage Floor Concrete PSI? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-08-2013, 01:52 PM   #1
Rewards Points: 260
Anyone have any idea what the PSI rating is for basic residential garage concrete floors? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 11-08-2013, 02:16 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 816
What it typically is or what you should have?
If your building a new garage, 3000 PSI is fine. If your going to put in a lift then your going to want pass under the legs.
4" is plenty thick....and if someone tells you that you need 6", ignore them.
ddawg16 is online now   Reply With Quote
Old 11-08-2013, 02:26 PM   #3
concretemasonry's Avatar
Rewards Points: 2,566
In Ohio, I would make sure the concrete was air entrained (5%) for freeze/thaw resistance since you could have a lot of winter droppings from the cars entering and melting/dropping.
Strength is not that critical but in some areas a supplier will not supply higher strength (3500-4500 psi) and air entrained, but they will freely give the names of smaller suppliers that will. - Not a big cost compared to everything else, but some suppliers want to avoid the disputes between homeowners and contractors that are cheap since the suppliers found it is cheaper to do that hassle.
Dick
concretemasonry is online now   Reply With Quote
Old 11-08-2013, 05:36 PM   #4
Rewards Points: 1,294
What the heck does this mean?????
danpik is offline   Reply With Quote
Old 11-08-2013, 07:40 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 816
It means I was typing on my smart phone while sitting on the head and the auto correct thought I meant "pass" instead of "pads"
Old 11-09-2013, 03:33 PM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Normally a contractor will order 3000psi and put so much water in it that it'll barely make 2000psi. If you're DIYing it, just take a bit of extra time and effort and don't over water the concrete. Trust me, when it doesn't have spider cracks all over the place, you'll thank me.
Plus, all that hard work makes the beer taste better.
Mort is online now   Reply With Quote
Old 11-09-2013, 05:31 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
In table 1904.3 of your Ohio codes, you will find that you are at 2,500 PSI for your application, PROBABLY.
I don't know your specific application so you are on your own here.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 11-09-2013, 09:33 PM   #8
Rewards Points: 3,348
All the redi-mix producers in our area won't mix anything less than 3000 PSI.
Canarywood1 is offline   Reply With Quote
Old 11-11-2013, 09:44 AM   #9
Rewards Points: 4,448
we don't use anything less than 3,500psi keep it dry ( not wet, no excess wtr ) as wtr:cement ratio adds greatly to the strength of the conc,,, air's good as dick post'd UNLESS you're also adding steel fiber for a super-strong more abrasion-resistant [ masterplate ] surface,,, as always, a proper install'd jnt pattern reduces the chance of random cracking
Old 11-11-2013, 03:05 PM   #10
Concrete & Masonry
Rewards Points: 470
Most garage floors "here" in WI get poured with a 3500 or 4000 psi mix, simply because it finishes better and sets faster than leaner mixes. The minor cost increase is generally offset by labor savings.
I should mention, just because the concrete mix is designed to meet or exceed 4000 psi at 28 days doesn't mean it will in reality. It really depends on a ton of factors, including slump, curing, etc....
jomama45 is offline   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
woodworkbykirk (11-11-2013)
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
