Garage Floor Coating - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-31-2012, 04:14 PM   #1
garage floor coating
I'm interested in putting an epoxy coating on my garage floor and I want some advice on a good product that won't peel or yellow. Any advice
ggoetsch is offline   Reply With Quote
Old 06-04-2012, 12:13 PM   #2
biggles's Avatar
prep is critical...just saw a couple of shows on the tube about that.biggest item was to clean the exsisting floor of dirt and grease/oil.
Old 06-05-2012, 10:36 PM   #3
Too Short? Cut it Again!
And if you are going to do this yourself, make sure the epoxy components are within the date expiration. There is nothing worse than resin that will not cure.
Some of the kits out there make finishing you own floor possible but you should definitely get an estimate or two from a company that has the equipment to mix the components together in the truck and lay down the surface in whatever color and pattern you want. It may come out cheaper and you will have recourse if something goes wrong.
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
