Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-04-2012, 08:02 PM   #1
Garage and driveway uneven
Hello,
I have an unattached one car garage on a home I just purchased.
My garage slab is newer and bc of this sits about an inch or so above my cement driveway!!:/ the height dif makes it uneasy to pull into garage entrance. I am looking for any help as to repairing this with out "pumping" driveway up or repouring the slab....
Thank you ,
Jeff
JTalaski is offline   Reply With Quote
Old 05-04-2012, 08:44 PM   #2
I bought a new home and that's the way they built it. Maybe 1.5 inches, actually.
Doesn't answer your question, though. You can get a concrete "turbo" circular saw blade for your circular saw. About $25. Draw yourself a good chalk line, set the blade about one inch deep and to 45 degrees, and in 5 minutes you are done.
Puttster
puttster is offline   Reply With Quote
Old 05-04-2012, 08:56 PM   #3
Ravenworks's Avatar
It is suppose to be like that,it keeps the rain water out.
Ravenworks is offline   Reply With Quote
Old 05-04-2012, 09:00 PM   #4
I'm with Ravenwood on this one. Without it there's going to be water inside the garage every time it rains.
Old 05-04-2012, 09:31 PM   #5
hello,
Thank you for the responses. The problem is there is a definite height difference between the slab of the garage and the driveway. It isnt a gradual slope, it is more like a "mini" step-down. I have to correct it to gain my certificate of occupancy because it constitutes a "trip hazard" per: the inspector. I am trying to avoid "mud jacking" or anything of the like just yet.
Old 05-04-2012, 09:35 PM   #6
Make him prove it in a code book.
I've never once seen a garage without that hump except some DIY pored slabs that fill up with water everytime it rains.
BigJim (05-06-2012)
Old 05-04-2012, 09:38 PM   #7
well do any of you know how to post a picture?? I have one on here but dont have a url for it
Old 05-04-2012, 10:31 PM   #8
I've heard more whining about the lip on the garage slab than anyone should have to endure in a lifetime.
An inch and a half is perfect.
Don't tell me what's next-you have to step up to get in the house?
cleveman is offline   Reply With Quote
Old 05-04-2012, 10:59 PM   #9
Ravenworks's Avatar
The width of a 2x4 exactly,at least that's how it's done around here.
Old 05-05-2012, 05:33 PM   #10
Originally Posted by JTalaski View Post
Hello,
Thank you ,
Jeff
Is this a new home?,if so the builder is the one that has to get a CO where i live.
Canarywood1 is offline   Reply With Quote
Old 05-06-2012, 10:40 AM   #11
my 5y/o garage doesn't have that. and I AM GLAD it doesn't !
i was going to go take a pic. but my junk batteries are dead again
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 05-06-2012, 10:42 AM   #12
oh. and it doesn't leak any water. and i don't even have a gutter, yet.
Old 05-06-2012, 11:57 AM   #13
it is a beautifull day outside today !
oh. the entrance door. that has a lip and a threshhold. i want to lower that as it is too high.
Old 05-06-2012, 02:06 PM   #14
Concrete & Masonry
hello,
Mudjacking certainly would be a good approach for a long-term solution.
For something cheaper & more temporary, you could "rip" a pressure treated 2x6 on a long angle from 0" to 1" or so, and place it against the garage slab. I can't think of any easy cementitious patch that would hold very long either.
As for the formed ledge as shown in post 2, it's certainly not a common practice here. The last 12" or so of floor is simply pitched more aggressively than the rest of the floor, and it generally is more than sufficient.
jomama45 is offline   Reply With Quote
Old 05-08-2012, 09:29 AM   #15
Any garage without this lip is wrong. Iv done many repair jobs where the concrete guys pour the driveway level with the existing garage slab and water blows in and creates problems. The i have to demo a large section of driveway and re-pour it up to the garage slab and 1" or so lower hoping i can still maintain a down slope. Sometime the entire driveway has to be redone because of this. Unfortunately for you, this is the correct way. Perhaps use a grinder to smooth the sharp edge off and make it a little easier to roll over.
Good luck.
TRUEPRO is offline   Reply With Quote
The Following User Says Thank You to TRUEPRO For This Useful Post:
Ravenworks (05-08-2012)
Driveway sloped toward garage, floods garage in heavy rain. ckkone Concrete, Stone & Masonry 13 02-18-2012 07:02 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 10:03 PM
Lip between Garage and Driveway formed over Winter ivanl3 General Discussion 4 02-27-2011 03:35 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
