Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-19-2012, 03:42 AM   #1
Question
Garage door area rain water backing up issue
Hi all, thanks for lending me your helping hands again...
Here is a photo.
and
(click on these pictures to zoom in)
As you can see, at our garage door area, every time when it's raining, there will be a big puddle forming, as the water can NOT effectively go into the drain. It gets worse if there are some leaves blocking the drain. Is there any good solution to solve this problem? Many thanks!
ohman is offline   Reply With Quote
Old 11-19-2012, 08:27 AM   #2
You have the perfect storm to make sure you get the max. amount of water into that garage.
That driveway needs to be regraded and or a trench drain sysem installed that goes across the whole lenght of the aprin.
http://www.ndspro.com/drainage-syste...gory-overview/
That drain you have now is all but useless.
Old 11-19-2012, 12:43 PM   #3
cut a floor train inside the garage and tie into the one that is not getting any water.
pwgsx is offline   Reply With Quote
Old 11-19-2012, 06:28 PM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,.... I think I'd saw cut it, 'n trench drain it, Outside, usin' the drain that's already there....
Full stretch like Joe said...
Old 11-19-2012, 06:43 PM   #5
That's a great idea to saw cut it and trench drain it. Thanks guys! By the way, what type of concrete saw or tools do I need to do that, and would I be able to rent such tools from local home center (in case they are expensive to buy them)? Thanks!
Old 11-19-2012, 06:48 PM   #6
Need one like this to cut deep enough and a jack hammer.
http://www.bing.com/images/search?q=...t=concrete+saw
Rent to small a hammer and you'll be there all day trying to break out the center of the two cuts.
Rain water issue ryanb4614 General Discussion 4 09-23-2012 12:27 PM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 06:36 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
